Old 9th October 2012, 03:48 PM   #381
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by soundaatma View Post
Hello Elias,
Good work here. Can you please direct me to the exact wiring scheme that you used to implement the "0.5" attenuation.
There are some similarities here to the Haas effect to extract surround ambient signals using L-R or R-L and sent to surround speakers.
Here the schematic I use for SSS. Matrix x=0.5. And there is the psychoacoustic filter to steer the energy at high freqs.
Yes SSS increases the perception of 'surround' since for example left side element signal is:
L - 0.5*R = 0.5*( L + (L - R) )
which means there is the 'raw' left signal and 'surround' signal with equal amplitude.
- Elias
Home page
If our hearing would be accurate, we would be hearing two loudspeakers.
Old 9th October 2012, 05:52 PM   #382
Thanks Elias. What values are you using for the resistor and capacitor Rps and Cps. Thanks.
Old 9th October 2012, 09:42 PM   #383
Elias's Avatar
The component values are 'hidden' here:
Elias Pekonen Home Page - Stereophonic Sound from a Single Speaker
But the answer may depend, as usual. It can depend on the driver's high freq response, and the room.
Good starting point is to choose Rps as about half of the driver impedance. The Cps value can then be used to tune the corner frequency, and is best found either by measurements or listening tests.
For 8 ohm driver one can start with Rps = 4.7ohm and Cps = 4.7uF. But as said, it depends
- Elias
Home page
Old 10th October 2012, 11:43 AM   #384
Thanks Elias, I discovered the hidden fine print on your website !
Old 11th October 2012, 10:18 AM   #385
Elias's Avatar
Interest on component values indicates you are building one ?
Home page
Old 11th October 2012, 12:56 PM   #386
Hmmm..i am planning on a portable laptop speaker, with 3 widerangers, run full BW. Something like a mini "soundbar"
Thanks for your help Elias.
Old 15th October 2012, 10:48 AM   #387
norman bates's Avatar
Hopefully your speakers have a flat resistive impedance curve.....................
Maybe 3 x fx120's.
I'd toss the cap and use a pot around the mono center speaker in post 381.
Keep your head the same distance to all 3 speakers and you'd have a winner.
I think I'll build something to test it.
A coffee table listener should work well.
Old 15th October 2012, 11:19 AM   #388
car stereo review 1990
How To - Car Stereo - How To Install A Center Channel
Old 15th October 2012, 11:31 AM   #389
Elias's Avatar
The capacitor may turn to be an essential part of the system.
It has the effect at high freqs of reducing the center element and boosting the side elements. This seems to be due to psychoacoustic requirements that the capacitor is to be used. It can be considered as energy steering of the stereo field.
And, at low freqs where the capacitor impedance is high the three elements work as a vector steering of the stereo field.
It is similar behaviour to Gerzon Ambisonics, which is based on low freq vector theory and high freq energy theory.
Now if you leave the capacitor out and use some resistor the frequency dependent nature of the function is no longer fullfilled.
- Elias
Home page
Old 15th October 2012, 11:35 AM   #390
true, it would be a simple summed mono fill speaker.
But I've heard it sounds great though.
Encel Stereophonic M.F.B CSM 40 amplifier Bass Man Tubes / Valves 0 6th May 2011 12:06 AM
Sound transmission loss in Loudspeaker diaphragms thadman Multi-Way 10 21st August 2009 03:40 AM
Sound card for loudspeaker measurement preiter Everything Else 8 13th August 2007 12:32 AM
Bell Stereophonic 3030 help AtomiKM Tubes / Valves 2 23rd September 2006 11:37 PM
Loudspeaker construction vs sound quality josefr Multi-Way 4 11th April 2003 06:24 AM
Copyright ©1999-2013 diyAudio
