Stereophonic Sound from a Single Loudspeaker - Page 31 - diyAudio
Old 12th February 2012, 03:59 PM   #301
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by markus76 View Post
Or even more than 8. Depends how much one is willing to do. Forget about Ambisonics, recording techniques are not going to change. What might change is how sound is stored. We need to get rid of systems with a fixed number of channels. And some work is done in that direction. With such a new approach the user can choose the playback system that suits him best.
Yes, recording techniques are not going to change. That fact also disables wide spread usage of multichannel in home audio reproduction.
Ambisonics is great for storing data. Only 4 channels (1st order Ambisonics) can store the whole sound field at the listening point. In Ambisonics the number of data channels is independent of the number of speakers used in reproduction. When reading pro recording and audio forums, one get's the impression that Ambisonics is much more common in recording and studio work than generally known. But practically no-one is using Ambisonics at home reproduction, though.
It's a fact that the sweetspot is small and all recorded music is really just made for a single seat. Doesn't matter if stereo or multichannel. A center channel helps. By the way, a single stereo speaker works by the same principle. The only difference is that there are no real side speakers but wall reflections.
Obviously you haven't followed the discussion very closely, or by some reason are dismissing the fact that the side wall room reflections produced by the SSS are in great extend decorrelated compared to the real speakers. This is the reason for the increased spaciousness that conventional stereo is lacking. Another feature of this decorrelation is increased ASW. And still another feature is lack of speaker localisation, which could occur if real speakers were used.
So one cannot say side wall reflections and a real speaker therein are identical without any difference.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 12th February 2012, 04:19 PM   #302
Banned
Sorry but multichannel is in widespread usage.
- Elias
It just didn't work for me, see Stereophonic Sound from a Single Loudspeaker
I got better results by simply setting up two additional speakers at 60. This increased ASW, which in combination with LEV forms "spaciousness".
It's also easier to control the amount of spaciousness with those two wide speakers. Increased ASW isn't appropriate for all types of content.
Power handling might also be slightly better than using smallish fullrange drivers. We also didn't talk about diffraction effects yet...
Old 12th February 2012, 05:27 PM   #303
Elias's Avatar
I don't know anyone in person who's using multichannel for home audio.
Cannot argue about taste and personal preference.
I would say non existent ASW is not appropriate for most types of music. This is where conventional stereo fails, no ASW.
If I would need more power handling (which I don't at the moment for home use) I would propably try one of these
http://profesional.beyma.com/pdf/6CX200NdE.pdf
About diffraction.. That is exactly the reason I stated earlier of one possible explanation why your miniature proto failed. Too much of diffraction, no baffle gained directivity. The directivity pattern must be steered according the stereo panning. If the SSS speaker is totally an omni it does not work.
- Elias
Old 12th February 2012, 05:34 PM   #304
Banned
- Elias
What would the ideal baffle look like?
Old 12th February 2012, 05:59 PM   #305
Elias's Avatar
Most likely the ideal is yet to be discovered.
In my current set up side panels are 40*33 cm. Other sizes could work too, as long as it is not too small.
If you would measure 360 deg horisontal directivity plot in stereo side panned signal condition of your miniature proto, you would propably find out the directivity steering is lacking in the midrange. That could explain your comment "everything is in the middle" because it acts mostly like mono omni.
- Elias
Old 12th February 2012, 07:03 PM   #306
Elias's Avatar
Originally Posted by graaf View Post
when TV is off I use it for background music in my living room too, and then, funny, people keep asking and asking where are the speakers?
You must stop teasing innocent people !
It may shock their habits on stereo triangle
Old 12th February 2012, 07:53 PM   #307
Banned
What about the size of the front baffle?
Old 13th February 2012, 01:33 AM   #308
I think it would work best with large side panels and side drivers located closer to the rear than the front. This would increase side directivity and lower the frequency of baffle step (where it becomes audible in front).
I would make the center panel as narrow as driver permits, unless greater enclosure volume is needed. The enclosure could be as tall as needed to provide interior volume.
Also would recommend either well-rounded corners or absorption on the faces to reduce diffraction off front corners of the enclosure.
This may not address every concern mentioned, but it should work better than incarnations to date.
-- Mark
Old 15th February 2012, 06:54 AM   #309
Radugazon's Avatar
After the first test, here is a normal and fearless evolution of the "SSS applied on a multi speaker group". Now the central speaker is also a five 12" array, curved baffle, same wiring, same drivers, but horizontal.
I will not enter in the details of the probable finger like lobes, but there is an happy consequence. In despite of the center element and of the matrix that for the common sense would reduce the stereo extension, there is a great increase of the maximal width. For the connoisseurs, this is not because the tweeters excite the reflections during some sharp transients. This comes only from the low mid bass. On some records, a double bass or a male choir can be projected at 60 degs on a side ( the base of the listening triangle is 5 meters and the listener is at 6 meters, it's not because of being the nose on the speakers). In some synthetic productions, this localization can even reach the 90 degs but this time with the help of the high frequencies.
Without the SSS, these extremes are each reduced of 30 degs.
Too wide is not realistic, I know, but this extra width happens for instance on some Haendel oratorios where it is said that the massive choirs are in the sides chapels of the cathedral, then it's not a fantasy but a better restitution.
God save the...Matrix !
Old 15th February 2012, 08:13 AM   #310
CLS is offline CLS  Taiwan
Awesome !
And you keep scaring people here !
Encel Stereophonic M.F.B CSM 40 amplifier Bass Man Tubes / Valves 0 6th May 2011 12:06 AM
Sound transmission loss in Loudspeaker diaphragms thadman Multi-Way 10 21st August 2009 03:40 AM
Sound card for loudspeaker measurement preiter Everything Else 8 13th August 2007 12:32 AM
Bell Stereophonic 3030 help AtomiKM Tubes / Valves 2 23rd September 2006 11:37 PM
Loudspeaker construction vs sound quality josefr Multi-Way 4 11th April 2003 06:24 AM
Copyright 1999-2017 diyAudio
