#281 | ||
Does the Realiser deliver as advertised in your opinion? Quote:
Additional channels for height and/or ambiance could also follow as appropriate, although I'm not entirely sure how to derive height cues. |
#282 |
Yes.
What's your impression of trifield? Does it add any spaciousness, making single images wider and taller or is it "just" a more defined and solid stage or something else?
Markus |
#284 |
Not a bad idea
![]() On the other hand, the traditional stereo triangle has been lacking proper ITD cues in a small room acoustic space until today, so old fashioned stereo triangle is really not better than SSS ![]() - Elias
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#285 |
Hehe... done in days ago:
Unconventional Techniques for Achieving Oustanding Stereo Imaging That's easily missed. (and only ScottG gave me a smile )Of course there're some major differences between Watson and my setup. But the principle of enhancement in ITD is in common, I believe. It may not be theoretically (or pollitically) correct, but compared with my previous 3-panel (3-channel) in optimal linear matrix and the following SSS (in single panel), this setup is indeed better in many ways, especially in imaging of course. ![]() (The 2nd best is, except for the cheap pine boards for the baffles, I didn't buy anything new, all spares. )
#286 | |
perspective is everything |
#287 |
I should note that derivations on the "Watson" theme have been done many times before.. usually with limited commercial success. Dynavector superstereo is the one that immediately comes to mind.
The basic idea relates to a wider angle loudspeaker placement with respect to lower freq.s. vs. what occurs naturally with head-shading and higher freq.s.. i.e. *lower* correlation at freq.s below 1 kHz. A better method would be just dispensing with those freq.s below head shading from their normal "frontal" placement (i.e. the Orion midrange and bass section in a Watson added configuration), and instead using only the effects channels as shown in Watson. Upper freq.s should be from a loudspeaker placement that are closer together (approaching 0 degree for the listener - i.e. straight in front) or synthetic mono as seen in this thread. I think the real question is just how high in freq. they should go? Based on the amount of separation between the loudspeakers, the closer they are the higher in freq. they can go without the need for blocking the spl-gradient toward the listener.
perspective is everything Last edited by ScottG; 10th February 2012 at 04:41 AM. |
#290 | |
when TV is off I use it for background music in my living room too, and then, funny, people keep asking and asking where are the speakers?
"high phooey and hystereo" - Yascha Heifetz Last edited by graaf; 10th February 2012 at 06:58 AM. |
| Encel Stereophonic M.F.B CSM 40 amplifier | Bass Man | Tubes / Valves | 0 | 6th May 2011 12:06 AM |
| Sound transmission loss in Loudspeaker diaphragms | thadman | Multi-Way | 10 | 21st August 2009 03:40 AM |
| Sound card for loudspeaker measurement | preiter | Everything Else | 8 | 13th August 2007 12:32 AM |
| Bell Stereophonic 3030 help | AtomiKM | Tubes / Valves | 2 | 23rd September 2006 11:37 PM |
| Loudspeaker construction vs sound quality | josefr | Multi-Way | 4 | 11th April 2003 06:24 AM |
