Stereophonic Sound from a Single Loudspeaker
Old 12th November 2011, 07:36 PM   #101
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by KSTR View Post
Hi Elias,
I own quite a few recordings, electronica genre mostly, and in general any modern stuff that doesn't care about mono compatibilty for vinyl and FM, which have bass signal panned all acrross the place.
I did similar experiments (with 3 small bookshelf speakers) a year back or so to test the capabilities of simple rematrixing methods for "soundbar" speakers which are coming in fashion more and more, trying different (and frequency dependent) matrix factors -- inspired by Gerzon's Trifield equations. With multichannel convolver/DSP outputs there is complete freedom of choices.
While it basically works quite well, it's not my cup of tea, I prefer (and manipulate my stereo signals deliberately for) true stereo bass which is required IMHO to provide any sense of spacial realism (stereo reverb tails of bass signals even when those are panned center, that is). Oftentimes we hear people say that we cannot localize a SINGLE sound source sound below 150Hz or so, but this plainly ignores the fact that TWO speakers (signals) can provide a "sense of direction" down low there, either with two speakers or rematrixed to three in a conventional Trinaural/Trifield setup.
- Klaus
Hi Klaus,
You've seen the pics of my first prototype of the single speaker stereo.. with the FRS8 and all.. There is no bass to start with
I'm using separate dipole bass below 200 Hz.
I may not recommend using this single speaker concept at bass, since at most recordings the bass is mono so it will be emitted as single mono speaker, which do not perform well in a small room acoustic space. I've talked about that earlier
Elias Pekonen Home Page - Dipole Bass vs Monopole Bass
What comes to the ability to localise bass, I've seen studies indicating it is possible down to the lowest octave 20Hz, BUT it may require free field conditions since in a small room (smaller than or comparable to wavelength) there is no propagating wavefield and ITD is ambiguous.
Using more than one bass loudspeaker with decorrelated signal (e.g. reverb) may externalise bass, but I cannot say for sure if it is localisable. However, my hypothesis is even externalised bass can help in generating more believable sound image because not heavily contradicting cues take place.
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 14th November 2011, 10:23 AM   #102
graaf is offline graaf  Poland
graaf's Avatar
looks like a competition for SSS - as it stands - Audyssey stereolitic audio docks:
"high phooey and hystereo" - Yascha Heifetz
Old 14th November 2011, 08:20 PM   #103
von Ah is offline von Ah  United States
von Ah's Avatar
Elias, I seem to have missed how you achieve the 0.5x matrix-ing of the stereo signal. Are you using passive attenuating, or DSP, or active filtering?
I'm enjoying the thread, regardless.
Old 14th November 2011, 11:16 PM   #104
CLS is offline CLS  Taiwan
Passive.
Old 15th November 2011, 05:17 AM   #105
Elias's Avatar
[/IMG]
Nowadays these things keep popping up like mushrooms after the rain ! General megatrend Maybe we'll see such a trend for SSS as well, one day.
- Elias
Old 15th November 2011, 05:25 AM   #106
Elias's Avatar
It's purely passive, see post #11. Very easy !
Note, similar idea can be used in other spread speaker matrix reproduction systems, like Trinaural, or the one CLS is using.
I'm integrating all the 3 channel speakers as one.
Looking at your avatar, you have potential ! You'll already have one element at the top of the box Now, but two more elements at the sides at do some rewiring
- Elias
Old 15th November 2011, 06:28 AM   #107
graaf's Avatar
- Elias
so You have flooded the center element?
Old 15th November 2011, 10:24 AM   #108
Elias's Avatar
At the moment I don't see a reason for that. I'm using the psychoacoustic shelving filter to adjust the balance between center and side elements. It seems to work well.
- Elias
Old 15th November 2011, 10:43 AM   #109
graaf's Avatar
basically it lowers the level of the center element in the HF? sort of electric pillow?
Old 15th November 2011, 12:20 PM   #110
Elias's Avatar
The filter is steering high freq energy from the direct sound (attenuation) to the side (boost) which will be reflected as indirect sound which adds decorrelation.
This will help in spatially homogenizing pinna cues ! The loudspeaker itself will not be localisable.
- Elias
Stereophonic Sound from a Single LoudspeakerHide this!Advertise here!
Encel Stereophonic M.F.B CSM 40 amplifier Bass Man Tubes / Valves 0 6th May 2011 12:06 AM
Sound transmission loss in Loudspeaker diaphragms thadman Multi-Way 10 21st August 2009 03:40 AM
Sound card for loudspeaker measurement preiter Everything Else 8 13th August 2007 12:32 AM
Bell Stereophonic 3030 help AtomiKM Tubes / Valves 2 23rd September 2006 11:37 PM
Loudspeaker construction vs sound quality josefr Multi-Way 4 11th April 2003 06:24 AM
