Design idea:
MTM with Beyma TPL-150 with wave guide above 1,2khz Volt 2500.4 or PHL 3020 below 1,2khz Digmoda DDC 520 plate amp and 2-way digital crossover Two separate chambers for the midwoofers, each chamber 40l, with port on the back pannel ; 7,5cm diameter x 13cm. Tuned to 40hz. size of the speakers h=90cm , w= 43cm , d=50cm total height with stands : 145cm production cost : Beyma TPL 150 retail us$ 480,00 Beyma TPL-150 pleated diaphragm tweeter - Beyma TPL-150 - Beyma TPL-150 high frequency tweeter. Beyma TPL-150 high frequency tweeter is available here at US Speaker. Beyma TPL-150 speaker components. Volt BM2500.4 retail 190 pounds x 1,6 = us$ 300,00 x 2 = us$ 600,00 Volt BM2500.4 10in 200W Mid-Bass Studio Range Chassis ![]() Digmoda DDC 520 retail us$ 900,00 http://www.madisound.com/store/manua...20-digmoda.pdf cabinet with stands : ?? ~ us$ 1500,00 ?? shipping and import taxes not included. total us$ 3500,00 each ![]() comments ? Last edited by angeloitacare; 5th November 2011 at 03:58 AM. |
#2 |
Tough to sell:
A. an expensive loudspeaker, B. an active loudspeaker, c. a loudspeaker that large with so little low freq. extension The looks are decent, but I'm not fond of the stand. If I were emulating an aesthetic it wouldn't be Magico of old (or new). I prefer something more like this in a stand-mount: AAD 7001 bookshelf speaker by Phil Jones Perhaps Anodized black on the front and back panels, and possibly metalic grey paint for the sides, top, and bottom. It's just "cleaner" looking to me.
perspective is everything |
#3 |
hi scott,
sorry o/t abit. have u auditioned the 7001i? cheers henry |
#4 |
Is the aluminium plate on the AAD only for cosmetics?
#5 |
...truth seeker...
Imposing, a real presence in a listening room. I think the drivers offer a lot of potential.
If they are to be 145 cm high, I would investigate the use of the volume around the stand to be devoted to low frequency extension. A tuning of 40 hz with an Fs of 32 seems to me to be wasteful...go lower. One of the aspects of the Magico design is the horizontal, laminar construction. My preference is for vertical grain orientation. Just sayin'
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#6 | |
a backloaded design would improve bass response, and a rectangular cabinet would be much easyer to build : ![]()
#7 |
I like it! I would investigate removing the small rear chamber of the TPL and putting it in a larger airtight chamber built into the cabinet. Then stuff it well with some Bonded Logic. You should get an even cleaner sound than we get at the studio on our monitors using the TPL. The stock chamber it a piece of junk and much too small to have room for a decent amount of absorption of the rear wave.
Greg |
#8 | |
some time ago i did take off the rear chamber of my Radian 950pb, to see if i would hear any difference, but honestly, i did not. So i don't know if take off the rear chamber of the Beyma would bring a perceivable difference. But if i realise above design or similar, where the back is encapsulated, i would eventually give a try and see.... who knows.... ! |
#9 |
Floorstanding transmissionline is indeed nice looking concept. Drivers are good also, i have heard very positive thoughts about lsv-achenbach speakers, your design uses the same drivers but is much better in looks!
#10 | |
| Magico Mini | Saltuk | Multi-Way | 240 | 3rd March 2010 10:12 PM |
| the Very Mini Magico Mini | zei | Multi-Way | 7 | 11th February 2008 08:10 PM |
| "compact loudspeaker factory visit from "magico mini" thread | Nanook | Multi-Way | 2 | 4th January 2008 07:30 AM |
| Page generated in 0.11484 seconds (82.10% PHP - 17.90% MySQL) with 11 queries |
