Old 4th November 2011, 05:45 AM   #1
Default Series connecting woofers XO's.
Hi. I'm building some MTM's and have 4 ohm mids, also have 4 ohm crossovers, but would like to end up with 8 ohm speakers.
If I only use 1 crossover and connect the 2 mids wired in series to it my cross point would change as it's designed for 4 ohms right?
So is it ok to wire the amp side of the crossovers in series instead of the mids? Please look at the attached image.
Thanks!
Old 4th November 2011, 06:55 AM   #2
just another
wintermute's Avatar
No I don't think that this will give you the desired results either. My initial feeling is that this will result in a higher order slope that what you intend.
You would be better off changing the crossover values to match the impedance of the series connected woofers.
The other thing is it sounds like either you have taken something that was supposed to be for a normal MT and are trying to turn it into an MTM, or you are using off the shelf crossovers. Either way the result is probably not going to be suitable.
An MTM has some specific requirements in the crossover design if you want to have a reasonably wide vertical polar response.
edt: and yes you are correct, using a crossover designed for 4 ohms with an 8 ohm impedance will shift the crossover point.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Last edited by wintermute; 4th November 2011 at 07:00 AM. Reason: add confirmation
Old 4th November 2011, 07:09 AM   #3
Moondog55's Avatar
Not just the XO point but the shape also
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 4th November 2011, 07:25 AM   #4
Tony.
Yes, this are off the shelf component kits. I made a pair using the same woofers but with 8 ohm crossovers at the same frequency as the originals and they turned out very good, but now I would like to use the 4 ohm crossovers that come with them instead of buying more crossovers. Guess I would have to do some testing.
Thanks!
Old 4th November 2011, 02:21 PM   #5
Thanks!
Hi, the short answer is yes it will be OK to do that, rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 4th November 2011, 02:33 PM   #6
Thanks Sreten!
connecting two 110v amplifiers in series on 220v mains muddasirwaheedmalik Solid State 66 11th September 2011 06:13 PM
connecting heatsinks in series reddish75 Solid State 10 13th July 2010 08:15 AM
Connecting OSCONs in series for high voltage. Fanuc Solid State 6 22nd March 2007 11:51 PM
Series connecting output Transformers. Shoog Tubes / Valves 55 12th February 2007 05:22 PM
Series woofers Milzie Multi-Way 11 10th January 2003 02:42 AM
Page generated in 0.08482 seconds (75.07% PHP - 24.93% MySQL) with 11 queries
