Old 3rd November 2011, 05:24 PM   #1
Kahooli is offline Kahooli  Abu Dhabi
Default Passive radiator on center channels
PWt/mWP
Has this been done? any reason not to? the c-c spacing of the PRs would be will below 1/4 wave at <60Hz.
I've seen plenty of ported centers in this fashion, just wondering if there would be any appeal in having PRs for the avoided resonant modes of the ports, as well as the added visual appeal of having more cones
Old 3rd November 2011, 06:22 PM   #2
Speakerholic
Cal Weldon's Avatar
No reason to avoid them but the L, C & R channels should all be the same.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 3rd November 2011, 06:37 PM   #3
I'm starting with my center, and then going from that design to make the L/R.
Sort of backwards from what many do, but I have a lot of single drivers I want to experiment with. There's a thread elsewhere on that particular topic.
Through coincidence it's turning out very similar to theZD3Cproject on zaph's site.
I had some 8" Dayton PR's lying around the honestly I want out of my way, and pondered using them instead of porting. I guess I could have posted it in that thread...
Old 3rd November 2011, 10:03 PM   #4
Originally Posted by Kahooli View Post
Through coincidence it's turning out very similar to the ZD3C project on zaph's site.
You could do a lot worse than copying that design outright, easy enough
to swap the ports for PRs noting they could go on the sides if wanted.
And as that design shows, you don't want the centre the same
as L/R. You want the same tonal balance from L/R and C.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
In praise of center channels bentoronto Multi-Way 88 18th February 2011 03:16 PM
Multiple Center channels. pixie Everything Else 7 31st August 2010 02:49 PM
Passive radiator Chris8sirhC Subwoofers 4 5th August 2008 05:49 PM
Adding center and rear channels nebelk Multi-Way 2 13th March 2008 06:05 AM
passive radiator ??? Ahmad_tbp Multi-Way 20 29th March 2005 07:44 AM
Page generated in 0.07337 seconds (71.68% PHP - 28.32% MySQL) with 10 queries
