I need to find a woofer that can be used without crossover. I also want a high efficiency woofer, that will work well with a tube amp. A compression driver will take care of the upper range, so it should roll off around 1000Hz.
What should i look for? |
#2 |
How big and how efficient?
Maybe Seas? A26RE4 - but it is only 89dB Seas Prestige A26RE4 (H1411) 10" Paper Cone: Madisound Speaker Store |
#3 |
I need someting around 95 dB. Don't care about the size, as long as the price is manageble.
Horn loading is also an option! What about this?
#4 |
bad.
eminence?
flesh flash flush
#5 |
Custom Title
JBL 2226h well controlled breakup that rolls off around 1500. BD designs BD15 has a smooth response but extends to 5k, so might be a good speaker to use fullrange+supertweeter.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#6 |
15W500 - LF Ferrite Driver
I personally have not heard this speaker, but have heard good reviews about it.
flesh flash flush
#7 |
18sound 15nd730. on axis @0.8 m w\o cross (yellow).
it seems, any (moderate Le) driver will have excessive on axis hf extension..
flesh flash flush
#8 |
Volt make a few possible candidates, the 251.4 is one of them:
Volt Loudspeakers - About Us 97dB and you get the choice of 4, 8 or 16 Ohm. |
#9 |
up to 5k!
flesh flash flush
#10 |
Custom Title
| "BEST" Woofer 50Hz - 300Hz & Hi eff, maybe 15" ?? | bear | Multi-Way | 163 | 26th November 2011 12:45 PM |
| Driver hight, how come it's so low? | Squeak | Full Range | 0 | 4th April 2011 12:05 AM |
| debt and hight perspective | Hylle | Multi-Way | 5 | 23rd June 2010 06:34 AM |
| fullrange/midbass driver I can run without crossover? | Greggo | Full Range | 0 | 11th August 2006 09:41 PM |
| OPAMP for hight V_swing ? | foo | Parts | 2 | 17th June 2006 07:07 PM |
| Page generated in 0.10800 seconds (81.44% PHP - 18.56% MySQL) with 11 queries |
