Never seen these before but at $5- at Aunt Sallies who could resist, i haven't yet hooked them up but i'm putting the pix here for comments.
Anybody have any experience with these?? Nice solid box and a bit of mass in the construction and Co-aXIAL SPEAKERS THAT ARE NOT FOR CARS ARE FEWER AND FURTHER BETWEEN THESE DAYS Sorry Stoopid caps lock on the laptop. I'll pull them apart in a short while and check-out the cross-over and the box internals. nominal rating is 8R and 40 watts program peak 80 watts.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#2 |
Box is sealed
Dimensions H= 260mm W = 145mm D = 125mm Nominally the woofers are 4inch 95mm measured at the halfway point on the rubber surrounds. There is a little rubbing of the VC . pictures of the insides follow in a short while
#3 |
What year are those from? I think they were an Australia only model. Possible?
Dan |
#4 |
I cannot find the manufacturer on the woofer markings. 115mm; rated 60 - 5000
nominal 14Ohms and 20 and 40 watts respectively both woofers in parallel. Cross-over has a cored inductor 0.5( I assume that's mH ) and 2 capacitors 1 * 4uF and the other 4.7uF.4uF cap is connected between the woofer + and - terminals?? the other two components form a second order high pass on the tweeter. No padding that I can find. The box is actually quite well made, baffle is chipboard but 25mm thick and it uses "T-Nuts" not screws and all panels are well joined and glued, only damping tho was a sliver of yellow fibreglass 5mm thick, not enough there to really do anything. I'm putting in some good damping pad i have sitting here doing nada and going to run them for a short while and have a listen
#5 |
Hi Dan
Doing a Google search it does look like Australia only 1983
#6 |
The tweeters look a little like and remind me of the Foster bullet that Tandy sold under the Realistic label.
Speakers are being given a bit of a work-out now, no point in using bad gear to test so they are working off the Rotel 1070 with the crossover set to the lowest setting ( 40 Hz) Hmm!! OK reset the XO to 80Hz and they sound a lot cleaner but a little brighter than my own speakers, I'm pushing them a little and they have no break-up yet, add a subbie or point five woofer and these may be OK, or should I just eBay them and ask a ridiculous price like $50- as a starting bid<??? They are after all extremely rare LOL. OK another trial, dialled the XO to 120 and turned on the bass amps, had to dial the subs down by 6dB to match the little speakers and to match mine I need to turn turn the subs up 2dB so not the loudest little speakers but with the subbies in the mix they really are OK crossed that low
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" Last edited by Moondog55; 3rd November 2011 at 05:30 AM. |
#7 |
Pix of the XO and the box construction
#8 |
SWMBO me hell for buying yet more speakers LOL
But Googling i just found an auction for ebay UK and a pair sold for UKP50- that's almost $110 -
#9 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 |
frugal-phile(tm)
Pictures of the back of the woofer (and PR?)
dave
| Realistic minimus 5 interest? | 60ndown | Multi-Way | 0 | 27th July 2011 01:07 PM |
| realistic minimus 3.5 | transaluminum | Full Range | 0 | 8th January 2010 09:42 PM |
| Realistic Minimus-7 how to | Zaffer | Multi-Way | 21 | 14th September 2009 05:51 PM |
| Realistic Minimus 7's in oak | cscmc1 | Swap Meet | 0 | 3rd August 2009 04:04 AM |
| WTB: REALISTIC MINIMUS/Optimus 7 Speakers | mrdon | Swap Meet | 0 | 28th May 2006 10:39 AM |
| Page generated in 0.09623 seconds (82.04% PHP - 17.96% MySQL) with 11 queries |
