Old 2nd November 2011, 08:01 PM   #1
Default How to compensate Baffle Step when placed in an open bookshelf
Hi I'm building a bookshelf pair for my father-in -law to be placed in the living room flanking the LCD television, the problem is that the television monitor is kept in an open bookshelf with no covering in the back. There is no another option to place the speakers anywhere else because the primary purpose of the speakers is to serve as speakers for TV because TV's sound is poor. Furthermore side wall supports only one side and another side is the passage...Should I use baffle step compensation..if yes how much..I think 6db or 12db will not work in this situation..I'm confused ..PLS ADVICE..THANKS
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
Open baffles & baffle step 5th element Multi-Way 13 15th April 2004 06:44 PM
Different ways to compensate bafle step Bricolo Multi-Way 3 19th July 2003 06:37 AM
Page generated in 0.05726 seconds (67.48% PHP - 32.52% MySQL) with 10 queries
