Old 2nd November 2011, 03:28 PM   #1
alspe is offline alspe  Finland
Default Designing principles for near the wall-speakers
How should be designed speaker, say ordinary 2-way standmount, so it plays nice almost against the wall? Like Rega R1, Linn Katan, Linn Kan are usually shown. About 5-10 cm from wall.
For little enclosure, speakers positioned like that do quite solid and fast sound because they radiate more 2pi because of back wall.
Should baffle step be corrected less or
bass tuning done as closed or
tune low Qts driver BR so bass response drops gradual for 200 Hz?
I think higher Qts driver is very no no!
Old 2nd November 2011, 04:49 PM   #2
It would be better to design an on-wall speakers. With near-wall placement there's a sharp notch in the lower midrange because of the rear wall reflection. Also, there will indeed be an increase in bass because of 2pi radiation and stronger excitation of room modes. These to effects will significantly mess up the balance that way.
Nevertheless, it would probably be best to use less baffle step correction for a speaker near a wall to prevent it from sounding bass heavy. The midrange notch remains, but you really cannot do anything about that except adequate damping of the wall behind the speaker.
Old 2nd November 2011, 05:58 PM   #3
It would be but near wall standmounter has advantage that you can fine sound with placement. In-wall speaker is where it is screwed to wall.
BSC and bass must be different than free space speaker. Asking, who has designed these?
Old 2nd November 2011, 05:58 PM   #4
doug20 is offline doug20  United States
Of course the sharp notch issue is pretty much a technical measurement one and hardly an audible issue.
The BSC changes though are have to be measured and maybe corrected outside of that its not a big deal at all in having near wall speakers. Only the most pedantic of audiophiles will "Think" there is a problem but then again no one really wants to follow some of the crazy ideas they have anyways
Old 2nd November 2011, 05:59 PM   #5
I only use active designs so that I can easily control placement and BSC. What are you really aksing though? You simply need to put your speaker design close to the wall and see what happens to the bass region then compensate for that change (if you choose too).
Old 2nd November 2011, 06:13 PM   #6
Since it occurs at a relatively low frequency, say 300 Hz, the reflection delay is very small (~ 3 ms) and the reflection is coincident with the speaker it probably is an audible issue. A listener might adapt to it because it is a constant colouration, though.
Old 2nd November 2011, 06:25 PM   #7
Wanna bet $$$ on normal playback audibility?? If its a sharp null then its easliy masked even at lower frequencies.....heck the room dominates everything below 300Hz anyways.
FWIW, I have done the controlled listening experiments on this exact topic. Before my room was treated I had speakers placement where the null was created around 200Hz or so. I did tests with panels that remove the null vs no panel. I even let friends try it out. They could not see me the speakers or the panels as I added them or removed them......there was a moment where someone thought "Hey, that is different/better".
Conclusion was that is purely a measurement issue and if someone is concerned over that then they have to solve it.
Old 2nd November 2011, 07:02 PM   #8
speaker dave's Avatar
I designed an onwall system at PSB (the VS300) that had a switchable EQ for the rear wall bounce. Relative to the free field performance the on wall measurement was up considerably at LF with a strong dip at 200Hz or so. The rear wall dip was easily audible, as was the bass rise.
The trick was creating the EQ with a passive network. I ended up taking advantage of the 2 1/2way design and gave the lower woofer 2 very different rolloffs.
For this to work you need to have a fixed distance to the back wall. That would be the case for an onwall with its own bracket. (Not necessarily for a bookshelf speaker and stand "kind of" near the wall.)
The VS300 worked very well and was elegantly finished, yet never a big seller.
David S.
Old 2nd November 2011, 07:36 PM   #9
bbggg is offline bbggg  United States
2pi loading can be compensated for. A really smart guy (ie not me) could probably design a vented enclosure that performs well in free space and then, if the vent is plugged, changes its response to one that is appropriate for half space. As for the mid cancellation dip, I guess the solution is a broad, preferably curvy baffle on the shallowest possible cabinet. This moves the dip upwards and, since octaves "grow larger" in frequency content as frequency goes up, it should become less and less noticeable. The LS3/5A, for example, would probably produce a dip at around 800 Hz if placed hard up against a wall.
High current requirement is the bane of high fidelity
Old 2nd November 2011, 11:25 PM   #10
Default On wall speaker correction
I found some curves for the VS300 with wall bounce correction.
The first curve shows the response of the system in free space and against the wall. Blue is free space and green is on-wall. Lots of LF lift from the boundary but at 500Hz the reflected source is 1/2 wave behind and heavy cancelation occurs. The curve is fairly wide as well as deep and was clearly audible as sucking the midrange out of voices. Note that there should be higher harmonics of cancelation but they are fairly minimal since the system directivity is rising.
The second curve shows a few different EQ curves. At the top is a gray difference curve between the 4 pi and 2 pi responses. The EQ needs to be the inverse of this curve to fix the on-wall response. The fix I used was via the 2 1/2 way woofer networks. Green shows the upper woofer response that never changes. Red and Purple are the "lower" woofer responses, achieved by network switching. Red is the normal free space or 4 pi response. Boundary correction comes from the Purple curve.
The final set of curve shows the on wall response without correction (green curve) and the boundary corrected curve in red. I didn't fully drop the bass response to flat (nobody complains about too much bass.)
So there, it can be done. But remember that it only makes sense if you can guarantee that the boundary location is fairly consistent, as it would be with a wall bracket mounted system.
David S.
Designing for on-wall/near-wall speaker placement morbo Multi-Way 4 27th November 2010 04:52 PM
In-wall Speakers advice DIFORCE Multi-Way 0 17th August 2010 05:11 PM
Wall Speakers ? Bigun Full Range 14 20th January 2009 07:30 PM
So, why not in-wall speakers? wigginjs Multi-Way 4 20th August 2007 02:59 AM
In wall speakers bostarob Multi-Way 11 23rd June 2002 06:12 AM
Page generated in 0.12086 seconds (83.55% PHP - 16.45% MySQL) with 11 queries
