#21 |
I too am a newbie and it is very hard to understand what is going on. The Cookbook assumes you have a knowledge of electronics. I was very fortunate to find a mentor in this forum who has/is helping me understand what I am doing. All I can suggest is find other projects people have done (surf the web: DIY Audio etc..) and spend hours searching this forum for anything you don't understand. It may take awhile but it does get clearer... When that first successful project sounds just right, its all worth it.
Good luck
Freedom is not hereditary. |
#22 |
A site which is worth visiting for beginners is
http://ldsg.snippets.org it has a good rundown of different loudspeaker enclosure types, some sensible advice and lots of links. Colin |
#23 |
ok I'll be checking out the sites that were mentioned and also see if the books that were recommended is available here (fat chance for that to happen
) I'll check out the one by weems and the cookbook.I've already done a sealed single sub enclosure and pretty much got the design basics for that type of enclosure. Is it more or less the same if I use more than one driver? |
#24 | |
Be careful when considering multiple drivers for the mids and highs though. Dispersion and comb problems could mean major difficulties for a beginner. |
#25 | |
TNT Audio Acoustic Line Source Research Harman International White Papers (for room acoustics) PS Audio |
#26 | ||
#27 |
There's an Aussie web site under construction that's promising specifications on the Dai-1Chi drivers. That will make it much easier to design speakers. You may want to keep checking them.
WES Components |
| diy sites | p robertson | Everything Else | 0 | 24th November 2005 12:43 PM |
| Some ESL sites | moray james | Planars & Exotics | 10 | 11th July 2005 05:03 PM |
| Best sites to buy ICs?! | deepanger | Solid State | 0 | 14th January 2003 12:06 PM |
| Page generated in 0.10021 seconds (81.21% PHP - 18.79% MySQL) with 10 queries |
