#11 |
FWIW with low Fs, high Vas, and highish Qts drivers rather than aperoidic perhaps 3rd order with big series capacitors is the best option for such drivers. The free version of Basta! is good for modelling it I've found. also see : http://www.humblehomemadehifi.com/do...20Box_copy.pdf You can't force drivers into boxes they don't want to go into. Two in 3rd order sealed on the left and right in force cancelling mode crossed over to a mid should be an option. I can't comment on whether one or two (or four) will be loud enough. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 30th October 2011 at 10:00 PM. |
#12 |
Dilletante, tinkerer and beggathoner supreme
I have used that design before on big sealed subwoofers but I thought the mass was a little low on these woofers. I thought that Qms needed to be about or above 10 to get the most benefit from this technique??
FYI the cap bundle for the Kicker was ~ 1400uF Thanx for the link I hadn't read the page or design
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#13 |
The midrange I will use is usable from about 150 up BTW in a small (3litre ) sealed as it is a small woofer (5inch ) with good performance to 4k and a reasonably low Fs of 58hz
#14 |
Anybody know how paste the screendump in W7?
#15 | |
You've lost me there, Qms doesn't come into it, Qts does. Qbox needs to be around 1.0 rather than the typical 0.7 or so sealed. higher Q drivers need big boxes to get to 0.7, this is where the 3rd order alignment helps. Qms = 3.7 and Qes = 0.53 ends up as Qts = 0.46. Fs = 30Hz, Vas = 92L. 90L per driver vented at 25Hz is a pretty good response, but that is IMO a far too big box for a 10" so forget it. Sealed for Q = 0.7 = 70L, 0.8 = 45L, 0.9 = 33L, 1.0 = 25L. So two with series caps should be around 50L to 65L. I haven't played with it for a while but Basta! models it. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 31st October 2011 at 12:47 AM. |
#16 |
I get a much bigger box to give that result but I am using a series resistance of almost .7R as that seems realistic given his amp and existing speaker cable and the internal wiring combined.
2 in parallel seem to model at 107dB given a 100 watts and Xmax limit
#17 |
Bass SPL max only depends on CSA, Xmax + frequency so saying its 107dB without a given frequency does not make a lot of sense to me. In the thermal limit region it it fixed, sensitivity + power handling, the excursion limited region is an entirely different matter, usually. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#18 |
This would be easy if I could paste the graph but for some reason W7 won't let me.
107dB from 100Hz to 60Hz and 10db down at 35Hz when the cap is placed in line
#19 |
OK this is at 100 watts in 75 litres and a first order electrical at 30 Hz nominal, modelled using JBagbys program
| "TECHNO"Amp building in progress-using "Iron Method" | zox2003 | Solid State | 23 | 30th March 2010 08:42 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Query regarding "stacking" T-lines | Volenti | Subwoofers | 6 | 11th November 2005 08:27 PM |
