Old 29th October 2011, 09:15 PM   #1
Red face Crossover between same speaker
Newbie... using the same model speaker for your bass and mids.... I am sure it has been done and may be done quite often. Can anyone tell me benefits and drawbacks... do the benefits outweigh the drawbacks. Seems to me freeing up the middle speaker and visa versa and having the same speaker model would make a cleaner crossover. Help me out guys. It is a vented design.
Old 30th October 2011, 09:53 PM   #2
if the driver has both good mids & good lows, no problem, except that baffle step will need to be dealt with in the xover. If you use one driver for mids+ bass, and the other with a 1st order xover at baffle step frequency for bass only, you get a "2.5" way xover, the simplest way to deal with BSC. 3 way or 2.5? depends on the capabilities of the driver (how loud you listen), & whether your amp can handle a lower impedance load.
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 30th October 2011, 10:26 PM   #3
AllenB is offline AllenB  Australia
The benefit you suggest is one thing but a crossover also creates problems when you attempt to blend sound from different locations. I wouldn't think it's worth it.
Old 31st October 2011, 12:11 AM   #4
1audiohack's Avatar
The JBL 4435 Studio Monitor is a fine example of a 2.5 way design.
Old 31st October 2011, 12:42 AM   #5
Speakerholic
Cal Weldon's Avatar
I agree with PeteMcK. You need a driver that handles the mids well and the .5 driver is your baffle step.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 31st October 2011, 09:48 PM   #6
http://www.parts-express.com/pdf/297-447.pdf
Well again I am a newbie. I know that dividing loads between speakers can reduce distortion. I was thinking of the above referenced speaker the m8n or m8a hivi. Its response chart seems fine and I am getting a good modeling in winisd in a vented system with 3 drivers without going to large box. May use one for bass and one for mids crossing to electrostat at 600-450. ??? If you all can share your experience it would be appreciated. I also had the curious idea of running three together working as a team uncrossed for bass and mids and crossing a two way very low cross to electrostatic for upper mids and up
JooJoo1234
Old 1st November 2011, 03:18 AM   #7
Dividing the range between a pair of drivers the way you have described, to reduce distortion is not worth the tradeoff. Your other idea of running a handful of them within the same range as each other will achieve the goal you are seeking in a much better way. What you would then have is a line array and I would suggest you research these if you plan to run them up in frequency.
Old 1st November 2011, 04:07 AM   #8
Thanks AllenB. I will read up! I understand there are phase issues? Potentially... will look into this...
simplest speaker crossover soundnovice Multi-Way 19 15th September 2011 01:22 PM
speaker setup and crossover help personinaboxthing Multi-Way 24 30th April 2011 03:26 PM
Crossover and Speaker matching centra Multi-Way 6 1st June 2010 11:56 PM
Crossover at speaker level? icebear Multi-Way 0 23rd November 2005 12:52 PM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.10987 seconds (80.47% PHP - 19.53% MySQL) with 10 queries
