Old 27th October 2011, 07:33 PM   #1
Paul W is offline Paul W  United States
Paul W's Avatar
Default Modeling stacked mid horns ?
To extend tight vertical polar response lower in frequency -in a limited space- I'm considering stacking a pair of mid horns. (To prevent the pattern from becoming too tight in the upper mids, one would probably be rolled off lower in frequency than the second.)
What can I use to predict or, preferably, model the polar pattern? Any reasonably priced or free software available in the pro world?
Paul
Old 27th October 2011, 08:02 PM   #2
ScottG is offline ScottG  United States
Hornresponse:
Hornresp
In particular:
"Horns with multiple drivers and arrays of multiple loudspeakers can be modeled."
No crossover modeling however, but presumably you could use the polar model's "curves" and do some modeling with Soundeasy.
perspective is everything
Old 28th October 2011, 04:08 PM   #3
Paul W's Avatar
Hi Scott,
Will horn resp do two horns simultaneously??? If it doesn't, I could get single horn directivity from HR or Axidriver and possibly use the directivity function in Soundeasy or LspCAD to sim the two horns.
I'm hoping for more of a "one stop shopping" solution.
Paul
Going 4 way - low mid / mid horns Speedysteve7 Multi-Way 10 15th April 2011 07:13 PM
Modeling stacked horns in hornresp letsbangout Subwoofers 12 25th November 2009 01:16 AM
Wooden mid horns Defo Multi-Way 43 5th November 2009 12:37 AM
mid top horns adircf Full Range 0 27th January 2007 09:01 PM
Goto mid-high drivers and horns giolight Swap Meet 2 17th May 2004 08:52 PM
Page generated in 0.07401 seconds (72.58% PHP - 27.42% MySQL) with 10 queries
