Hello All,
I have been wanting to build a Jig for use with Soundeasy that would have everything I needed in one box. This would include the Neil/Wallin Preamp, a TDA2040 Amplifier, the PSU for both, and the appropriate components to complete all driver measuring. Something similar to this: ![]() ![]() First, is there a detriment to the measurement results by going this way and if so how? Second, I need a little guidance for finalizing the design. The Neil/Wallin Preamp used a 9v battery for power and I would prefer the jig to feed the preamp the necessary power instead. I would also like the TDA2040 Amplifier to also get its power from the same source if possible. I am ok with the PSU only supplying 9vdc to the amp if I can can intelligently only use one transformer and PSU to feed both. Does that make any sense? These are the schematics for the Amp and Mic Preamp: ![]() ![]() And finally, the schematic of the the original jig viewed in the first pic up top: Thank you for your thoughts and consideration. Cheers Last edited by Gavinator68; 26th October 2011 at 01:13 AM. Reason: Adding Info |
#2 |
just another
The main concern I would have is whether or not you would have noise problems with the mic pre running off the powersupply rather than from battery. At a minimum I'd suggest a a regulator circuit for the mic pre. You could pick up off the -ve rail for the amp.
You may also have noise pickup problems in the mic pre from emi from the transformer. My walin mic preamp is in a diecast aluminium case and runs off battery and I don't seem to have any problems, but I've never tried it out of the box near a transformer. Tony. |
#3 |
The gentleman that built the one I am trying to emulate indicates that he has no problems with EMI issues.......
Hmmmmm |
#4 |
Winter,
Would you have any insight into the PSU issue I speak of? Cheers |
#5 |
just another
Looking at the schematic for the amp it is set up to use +ve -ve and zero volts rails. you will not be able to run it off a single 9V supply.
What I would suggest is that you make a suitable supply for the amp (I don't know what voltage it should use, maybe +- 15V? and to have a separate reg circuit running off the positive rail which drops the voltage to 9V for the mic pre. That is if you only want to use a single transformer, for both the amp and the mic pre. You will need a dual secondary or centre tapped transformer to get the +ve and -ve rails for the amplifier circuit. regards, Tony. |
| Soundeasy, M-audio USB pre, two calibrated ECM8000, Wallen Jig | jmillerdoc | Swap Meet | 3 | 24th October 2011 07:08 PM |
| ARTA SOUNDEASY JIG set up | JMB | Software Tools | 0 | 19th January 2010 05:53 PM |
| Soundeasy probe/jig: Zaph versus Neubecker | jcandy | Multi-Way | 2 | 10th August 2009 04:45 PM |
| Complete SoundEasy 14 setup - Firewire 410, Mic, Jig, TrueRTA, more | major | Swap Meet | 2 | 20th March 2009 05:32 PM |
| SoundEasy Jig - Will it fly? | taj | Multi-Way | 11 | 22nd March 2007 12:58 AM |
| Page generated in 0.09301 seconds (76.66% PHP - 23.34% MySQL) with 10 queries |
