What about the quality of BOSE's crossover network devices for their acoustimass sub-sat systems like "SE-5" (SE5) ?
And what is the aim of the lamps, that illuminate the interior of the chamber (have a look to the attached pictures) ? Some people tell me, BOSE is claimed by their speaker demonstations, that only the best components available on the world market would be used in their speaker devices. Because I don't know about the technology of the Bose crossover networks this above mentioned (for several readers stupid) questions. Thank you for comments and advices. Last edited by tiefbassuebertr; 25th October 2011 at 09:26 PM. |
#2 |
The lamps are a common trick for speaker protection. Their cold resistance is fairly low so they pass most of the signal. If you play too loud then they will heat up and their resistance will rise. This puts a soft limit on input signal.
Not real elegant but it works. David S. |
#3 |
"Some people tell me, BOSE is claimed by their speaker demonstations, that only the best components available on the world market would be used in their speaker devices."
Best??????? Try "components that cost us next to nothing with a HUGE markup for the consumer" Bose' strengths are their marketing ploys to convince people to pay way too much for what they get in return. |
#4 |
they don't even use solder, LOL. They just wrap the wire around those little posts.
#5 |
Cheap bipolar caps, thin wire, poorly dressed low cost labour wiring job, cement wire wound resistors, small guage inductors, was there any dampening material in the cabinets to absorb cabinet reflections? - more overpriced Bose crap
#6 |
the parts quality is pretty common for mass market, mass produced speakers.
Iron core inductors and electrolytic caps indicate that this item was built pretty much as cheaply as possible. Without the lamps the speakers would fail pretty quickly so they are a good inclusion. To improve the design one could substitute air core coils and film caps with the caps having the most influence on the sound quality. |
#7 |
Those pics confirm what most of us knew - Bose quality is extremely low.
They are not h-fi speakers. |
#8 |
Properly done wire wrap is very secure.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#9 |
I agree, I used to LOVE Bose equipment but I think after the 901 Series 3 they have started to ride their own coat tails.
I would expect higher quality from them but in the world of Hi-Fi they are not even in the top 100. The Bose 901 Series' 1-3 could be plugged directly into a 110V outlet and produce an ungodly loud 60hz hummmmmmm. Modern 901's will blow up. There are a pair of 501's I have been eyeballing at the local pawn shop for $300. I wonder if I pulled them apart, replaced the BP's with Polypropylene and the inductors with heavier gauge if they would be worth the investment? I know I could build an awesome pair of speakers for $350 that would at least as good. P.S. - Properly done wire wrap is GREAT, Poorly done wire wrap is a fire waiting to happen in certain situations. Last edited by Einric; 26th October 2011 at 12:26 AM. |
#10 |
Looks like rebuild time
I would replace the electrolytic capacitors with polypropylene since they last much longer. Generally the electros start to dry out after about 15 years but polys last much, much longer. Normally this is fine, the foam surrounds blow out about the same time as the electrolytics dry out so... The inductors I would keep stock--spend the money elsewhere since no matter what you stuff in the crossover--it is still crossing too high in frequency to work properly. I believe the frequency is around 200 Hz or so. The light bulbs as others have pointed out act as limiters--they burn off excessive voltage to protect the speakers. I had protection bulbs in a pair of JBL ProIII 5" woofer/1" tweeter small speakers about 20 years ago--the port tube would light up if I got too crazy. The wire wound connections on the inputs is secure but they can develop corrosion after 10 to 20 years. Two options, either unwrap and resolder them or you can replace the input plates with 5 way binding posts if you like. That will give you a much more secure connection. Had a buddy that inherited a set of those SE5's--he really didn't like the sound of the cubes so replaced them with 4 ohm JBL ProIII speakers. That caused the passive crossover to start tapering off the bass to the ProIII at 100 Hz instead of 200Hz stock settings due to the lower impedance. He stuffed the "bass module" between the two JBLs, adjusted his EQ a touch and liked the sound much better. Good luck! |
| TDL reference standard speakers | Moondog55 | Multi-Way | 14 | 26th December 2011 05:21 PM |
| Zobel networks in an active speaker/crossover | SteveVaiRules | Multi-Way | 17 | 31st January 2011 10:40 PM |
| KEF 105.2 crossover networks | drkool | Multi-Way | 6 | 2nd January 2011 10:16 PM |
| Crossover Networks | jteef | Solid State | 1 | 19th November 2006 08:24 PM |
| Need info about BOSE Jewel cube. Can I connect to standard AMP? | marcuswrk | Multi-Way | 1 | 29th August 2004 07:30 PM |
| Page generated in 0.11679 seconds (79.49% PHP - 20.51% MySQL) with 11 queries |
