Recommendation of speaker elements (2-way, floor-stander) - Page 2 - diyAudio
Old 1st November 2011, 04:33 PM   #11
onda is offline onda  Sweden
Originally Posted by sreten View Post
Seems you can get values in the USA that are not "standard". Like 2R and
8R where the actual standard 5% tolerance values are 2.2R and 8.2R.
Using 5.6R will dull the treble very slightly, room furnishings make far more
difference, so its effectively next to no difference, very unsubstantial.
rgds, sreten.
As this is my first build, I doubt I will hear any difference.
Final question though, will the different voltage of the resistors make any difference, or is the value just an indicator of how much voltage the resistors can handle?
Old 1st November 2011, 04:52 PM   #12
diyAudio Member RIP
Hi, edited last post to answer that, rgds, sreten.
Old 1st November 2011, 04:56 PM   #13
you may get close to 5.1 ohm simply by parallelling two 10 ohm.
crazyhub
Old 2nd November 2011, 12:03 AM   #14
Billyo is offline Billyo  Australia
The LBS design would probably cost me even more. Thanks for the suggestion though.
I found to my surprise that to get a really great result, the costs that are bandied around of a few hundred dollars for a pair are waaay to low for your first build (well... mine anyway), because they dont take into account the equipment that you'll need to buy.
Don't forget things like a sawtable, circular saw, saw blade, vise, somewhere to attach the vise, binding posts, glue, primer, color coat, clear coat, sand paper, sander, drill, drill bits, router, router bits, multiple clamps, glue, screws, long rulers, set squares, circular jigs, putty (I grew to love epoxy putty!), etcetera...
Sure, you could go and get the pieces pre-cut, but then if you ruin a bit, then you'll have to go back... also, I think that you're cheating a bit on the whole DIY experience.
All of these will add up big time, but once you have them, second and subsequent builds will be cheap. My advice is not to scrimp on your drivers and components, because their cost is relatively small compared to big ticket expenses like the saw.
Epoxy Resin fixes everything!
Old 2nd November 2011, 10:16 AM   #15
I agree with you completely. Fortunately for me, my father has a well-equipped garage, containing most of the tools I will be needing. As for the low budget of the elements, this build will be part of a school-project (its my last year at high-school), where price (excluding tools) is one of my primary concerns.
Either way, the drivers and crossover components are ordered! I have made a preliminary CAD-drawing, and I will probably go buy some MDF next weekend, so I can start building.
Thank you all for the help!
Old 2nd November 2011, 11:15 AM   #16
_henry_ is offline _henry_  Australia
hi onda,
please do share your cad drawings. the AMIGA looked very interesting.
heard many good things about the RS180.
cheers
henry
Old 2nd November 2011, 01:57 PM   #17
Michael Chua's Avatar
Hi!
I have found Troels Gravesen's design, using Vifa PL18WO-09-08 + XT25TG30-04 (Vifa PL18WO-), but it seems to have very little information on sound and so on. My question to you is, do you have any other recommendations on elements + crossover, with better value than the Troel's design? Any help would be greatly appreciated!
I have a Vifa PL18 in a bookshelf size. Quite a nice driver but difficult to cross in a 2-way.
For a floor-stander, check out my Dayton RS180 in a 40L mini tower.
ampslab
Super High-End 3-way floor-stander gornir Multi-Way 122 23rd March 2017 03:46 PM
tannoy 607 - speaker elements - use in a project trondareo Multi-Way 2 30th April 2015 10:53 AM
Designing Own Speaker Elements Ultima Thule Multi-Way 54 10th March 2010 03:19 PM
floor stander speaker system zackkstar Multi-Way 1 12th June 2006 03:13 PM
Copyright 1999-2017 diyAudio
