Old 24th October 2011, 09:45 PM   #1
jacdoc is offline jacdoc  United States
Smile Tivoli Model Two Speaker - Open Up?
I am trying to drill a small hole in the top of this speaker to install a wall bracket. I want to open up the speaker first to make certain I do not destroy anything essential. Does anyone have any instructions on how to remove the wooden box casing or take out the metal insertion? Or do you have any diagrams or photos of what it looks like opened up?
thanks!
Old 24th October 2011, 11:10 PM   #2
Inductor's Avatar
You would be destroying an antique... use instead a rack type or small Tv/speaker shelf.
Old 25th October 2011, 12:57 AM   #3
ShinOBIWAN's Avatar
Unless I'm mistaken, they're fairly recent.
Tivoli Audio Model Two Radio
Old 25th October 2011, 11:28 AM   #4
Ile is offline Ile  Finland
It looks like it's similar enclosure that Tivoli radios have.
Open those six screws from back plate embeddings and then you can pull back panel out. Sometimes it's bit tight, but cranking it out (gently) with screw driver from screw holes helps.
Front panel can be pushed out from inside box so that you wont scratch it trying pulling it outside.
I guess there's nothing inside box except that 3" element at front plate and cable to back panel.
I'd drill wall bracket holes to back panel, so there wont be visible holes on top panel.
Tivoli Model ONE vs. KLH Model TWENTY ONE tiefbassuebertr Solid State 11 15th January 2012 11:20 AM
Tivoli speaker Kees Full Range 21 24th February 2011 05:53 PM
drivers used in Tivoli Model one ? jives11 Full Range 9 22nd December 2010 05:18 AM
Tivoli Model 1 FM aerial connector replacement ? jives11 Parts 1 3rd March 2007 04:40 PM
Tivoli Model One Aux Input Modification YoungClay Parts 3 18th July 2005 09:19 AM
Page generated in 0.07142 seconds (73.06% PHP - 26.94% MySQL) with 10 queries
