I read a while back about some loudspeaker box having an annular port around the periphery of the driver (well, tautologically speaking anyway
Anyway, if I could wave a magic wand and make any kind of driver at all, I would try something like I drew in the attached drawing. (Will someone please call the tautology police? )The port is now incorporated as part of the centre pole piece. Both cone as port share a common centre. Also, centre pole cooling would be great! Over to you...
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#2 |
What's the point? At the wavelengths involved, the port can be quite a distance away without affecting "phase" or "time relationships" in any meaningful way. One more example of creating problems while trying to solve one that doesn't exist...
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
50hz=6.8metres long,so no 1/4 or 1/2 wave effects can harm anything as i understand it.....
but long box dimensions, could get into it. it looks cool anyway port in the cone who wouldve thought! |
#4 |
Agree with SY. In fact you create more problems because the mutual coupling between bass port and driver can’t be neglected anymore. The work of Thiele and Small ignores mutual coupling. Note what counts for a bass reflex port is the mass of air herein. For substantial mass you need substantial cross section area of the port. This means a large hole in the pole piece. Cheers |
#5 |
Graham,
By fitting a dustcap, mounting that driver in the middle of a door, and extending that tube out long enough you could make a dipole with TL loading. Eric / - More crazy ideas inspired by Graham.
I believe not to believe in any fixed belief system. |
#6 |
diyAudio Moderator Emeritus
Leave Graham alone.
Remember, they thought Galileo's ideas were crazy.
Rodd Yamashita |
#7 |
I think I also once mentioned that Graham was an unlimited source for crazy ideas.
But I don't regard this as a negative attribute ! Regards Charles |
#8 |
They said Edison was crazy. They said Einstein was crazy. They said Joe M. Varilla was crazy.
#9 |
Such a driver allready exists. There was quite a writeup in Voice coil a year ago or so.
Mark
#10 |
Actually, all modern tannoy dual concentrics have a bass driver with a hole through the middle for the HF unit. Ive got a pair salvaged. Doesnt sound that great without something there.
| Port position on Bass cab | Gubbe | Instruments and Amps | 1 | 17th February 2006 03:40 PM |
| Tannoy Dual Concentric Driver Unit | PTSOUNDLAB | Multi-Way | 4 | 13th March 2004 08:31 PM |
| Jamo Concentric Port Patent.... | mrfeedback | Multi-Way | 8 | 4th June 2003 02:08 AM |
| dual concentric bass drivers? | bbaker6212 | Multi-Way | 0 | 11th March 2003 02:00 AM |
| Concentric driver AND series XO | KlaasH | Multi-Way | 1 | 13th September 2002 07:07 AM |
| Page generated in 0.09607 seconds (77.98% PHP - 22.02% MySQL) with 11 queries |
