Old 9th September 2003, 12:45 AM   #11
mrfeedback's Avatar
Leave Graham alone.
Hey, I never said Graham is crazy.
I have said that I suspect the water where he comes from.
Eric / - Never Drinks Tap Water.
I believe not to believe in any fixed belief system.
Old 9th September 2003, 03:25 AM   #12
Brett's Avatar
A lot of air moving through the pole peice could be beneficial in cooling a pro driver that's absorbing several hundred watts for hours on end. Otherwise, I don't see much point.
Old 9th September 2003, 07:08 AM   #13
Default re: cooling
JBL uses the reflex port of their cheap active P.A. speakers for cooling purposes, though they use it for cooling of the amp.
But I remember seeing a drawing (about 20 years ago) by Sony, showing a speaker where they made voice-coil cooling by the use of a bent heat-pipe. The heat was transported to a some radial fins inside the reflex tunnel.
There is no reason why Graham's principle shouldn't work. But you will be very restricted regarding tube diameter and the range of possible tunings.
Charles
Old 9th September 2003, 07:35 AM   #14
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Default Re: Bass driver with concentric port.
Originally posted by Circlotron
Anyway, if I could wave a magic wand and make any kind of driver at allOver to you...
if i could i'd wish for a full range (line source, planar or other) and forget about the vented pole piece.
...still looking for the holy grail.
Old 10th September 2003, 09:29 AM   #15
ir is offline ir  New Zealand
Send a message via ICQ to ir
Fender use this sort of design in their amps but with the dust cover
reason being, as the dustcover is moved in and out, it draws/blows air thru the middle thus cooling the whoel arrangement. If it didn't, the 4x12inch drivers in a 100W cabinet could get mighty hot after a gig at full volume
Old 10th September 2003, 11:58 AM   #16
Circlotron's Avatar
My long term goal of course, is to stealthily break your brains. Buahahaha You only get to see a small percentage of the ideas....
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 10th September 2003, 12:12 PM   #17
just another
wintermute's Avatar
The thing I wonder about is what effect does the dust cap have in the overall radiation of sound??? (not really knowing anything about the physics of it)
If you have a hole in the center of the speaker up to maybe 5cm or more in dia, isn't that going to effect the ability of the driver to move air?
moreover if the air is rushing into the port as the driver moves out, and vice versa, wont that make things even worse?????
I probably need to read up again on ports and phase!!!
Tony.
Old 10th September 2003, 12:46 PM   #18
SY's Avatar
Dustcaps become important as you move into the midrange- for a sub or atrue woofer, they don't have a huge effect.
Yes, having a hole instead of diaphragm will decrease the amount of air moved for a given displacement.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 10th September 2003, 12:48 PM   #19
Dust caps can be taylored for the upper frequency range, therefore some drivers have very stiff dust-caps. Without any dustcap also the radiating area is smaller.
But it can still be made working well, just have a look at all those coaxial drivers, drivers with a phase-plug and of course all those where the dust-cap is just that: a DUST cap !
Regarding the 100 watts guitar speaker: I personally do not regard 100 Watt speakers as real high-power speakers and I think it would work with airtight dustcaps as well. A human being radiates more than 100 Watts of heat into his surroundings on average ! There are closed-box subs in the KW range that don't cook when operating. There are even closed P.A. subs that can take a lot of average power: www.bagend.com
Charles
Port position on Bass cab Gubbe Instruments and Amps 1 17th February 2006 03:40 PM
Tannoy Dual Concentric Driver Unit PTSOUNDLAB Multi-Way 4 13th March 2004 08:31 PM
Jamo Concentric Port Patent.... mrfeedback Multi-Way 8 4th June 2003 02:08 AM
dual concentric bass drivers? bbaker6212 Multi-Way 0 11th March 2003 02:00 AM
Concentric driver AND series XO KlaasH Multi-Way 1 13th September 2002 07:07 AM
Page generated in 0.10152 seconds (78.93% PHP - 21.07% MySQL) with 11 queries
