I wasnt sure where to put this so mods please feel free to move if this is not the correct section. I am curious the frequency range required for each of the channels in a 9.1 system. I cant find this range anywhere. Is it safe to assume that when designing a center channel I need to be able to reproduce 40-20k hz? Is there a guide for what frequencies go into each channel? Front(main), center, front height, front wide, surround, and rear.
#2 |
Most receivers will allow you to set the crossover points manually, or if you have one with room eq, like Audyssey, it will measure your speakers and set their crossover points automagically and route whatever is left over to your subwoofer.
I think the THX recommendation is 80 hz, but with a modern AV receiver you can probably tinker with it as much as you want independently for each speaker set, I.E Fronts, Surrounds, Rear Surrounds, Heights, etc. |
#3 |
thanks for the response so basically it would be best to setup 8's, 4's and a tweeter for each and i would be covered
#4 |
| in-room frequency response & transient response | MCPete | Multi-Way | 1 | 8th October 2011 06:31 AM |
| Frequency response | 2litre | Analog Line Level | 5 | 31st May 2006 07:00 PM |
| Group Buy for 5.1 Channel PCB's for Computer Surround Sound | DSchmidt | Group Buys | 2 | 1st January 2006 06:28 PM |
| frequency response | pmarcouxx | Digital Source | 2 | 20th July 2005 07:43 PM |
| Doubts on Phase Response and Frequency Response | dumrum | Multi-Way | 11 | 5th April 2004 10:39 AM |
| Page generated in 0.07148 seconds (71.54% PHP - 28.46% MySQL) with 10 queries |
