Help with Rear Loaded Horn Design
Old 21st October 2011, 06:16 PM   #11
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Originally Posted by dirkwright View Post
OK, so back to the front La Scala horn. Do you have any suggestions on how to fold up a straight horn to make it fit in the La Scala style enclosure? Also, I was told that a La Scala style horn with the parallel top and bottom boards would sound bad at the higher frequencies.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 21st October 2011, 06:21 PM   #12
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Yeah, I've got those plans, but thanks. Those plans are for a different driver, not the one I have already.
Old 21st October 2011, 06:29 PM   #13
Helmuth's Avatar
import the txt file of the sm115 in hornresp and change the driver parameters to your driver.
Old 21st October 2011, 06:50 PM   #14
dirkwright's Avatar
OK, I'll give it a try. Thanks!
I'm looking at the tractrix horn again in volvotreter's spreadsheet. It sure does look attractive...
Old 21st October 2011, 06:54 PM   #15
John Sheerin is offline John Sheerin  United States
You could make a conical horn 65cm long that would hit 100Hz in 1/2 space with your driver.
Old 21st October 2011, 07:02 PM   #16
dirkwright's Avatar
I can't seem to duplicate that in Hornresp. The conical horn is still 1 meter long. How did you do it?
Old 21st October 2011, 07:05 PM   #17
Try this:
S1 300
S2 2500
Con 65
Ang 2xpi
Vrc 15
Lrc 15
Vtc 500-3000
Atc 522
Old 21st October 2011, 07:08 PM   #18
Helmuth's Avatar
I would not do that you will be fooling your self you because it will not make a perfect fit with the corner. Calculate 1phi and hope you get that as result in the corner half-space.
Help with Rear Loaded Horn DesignHide this!Advertise here!
My first front and rear horn loaded fullrange design: help needed from The Wise. maxlorenz Full Range 35 2nd March 2014 01:19 AM
Help with a rear loaded horn design? Boscoe Multi-Way 2 21st October 2011 04:01 PM
How to design folds in rear loaded bass horn tstt9000 Multi-Way 3 26th August 2007 03:59 PM
rear loaded horn farriswheel Car Audio 2 27th July 2007 05:03 AM
Rear Loaded Horn David R. Carlso Full Range 3 9th January 2006 10:04 PM
