Your way to choose drivers
Old 21st October 2011, 03:22 PM   #1
alspe is offline alspe  Finland
Default Your way to choose drivers
What is your way to choose drivers for your multiway design?
What are most important details you watch?
sensitivity between each driver?
sensitivity overall?
frequency response, smoothness?
impedance trace peaks?
distortion measurements from somewhere?
usable bandwidth outside band?
price/value?
Old 21st October 2011, 03:50 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Good looks is what I go on.
Old 21st October 2011, 03:57 PM   #3
Inductor is offline Inductor  Portugal
Inductor's Avatar
It should be well documented and well built.
Also no metal diaphragms is usually a good policy (to say what I don't look for).
When choosing drivers (let's say for a 2-Way, a 3-Way or a PA) is different from when comparing drivers and from when simulating loudspeakers (and crossover), you need a well documented driver and/or measuring equipment.
Usually the sensitivity is a good sign of the "quality" but,
You look for other things first when building let's say a 3-Way.
Here I would look first for the best Mid driver. Usually beginers will look for the woofers they like first. So where are you starting first, and what type of drivers are you looking for.
Loudspeaker Selection
http://www.parts-express.com/resourc...-a-speaker.cfm
Old 21st October 2011, 03:57 PM   #4
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
price/value?
you forgot
Rms
Qes
Qts
Step response
Waterfall
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 21st October 2011, 04:45 PM   #5
Helmuth's Avatar
X max
Old 21st October 2011, 05:37 PM   #6
Charles Darwin is online now Charles Darwin  United Kingdom
Frequency response,
distortion,
Xmax,
waterfall
and price.
Old 21st October 2011, 05:42 PM   #7
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Start by buying the midrange and a 4X4 sheet of plywood. Mount it in the center and listen to just them. If you like what you hear, the rest will be easy.
planet10 needs your help:
Let's help Ruth and Dave
Old 21st October 2011, 06:24 PM   #8
DrDyna is offline DrDyna  United States
DrDyna's Avatar
I usually have a design in my head first and then choose drivers based on how well they fit into my plan, or I pick one driver I really like (specs / unique design) and find mates for it, such as this woofer:
ScanSpeak Illuminator 18WU/8741T 7" Woofer, 8 ohm: Madisound Speaker Store
Dreaming about what tweeter would work with it has woken me up quite a few nights!
Old 21st October 2011, 07:25 PM   #9
crazyhub is offline crazyhub  France
Targeted bandpass width, volume and efficiency usually are of main importance in my design criteria.
As speaker design always is a matter of compromises I try to keep the highest level possible on a mix of all the caracteristics of the selected drivers.
I never favour one single caracteristic to the detriment of all the others.
crazyhub
Old 22nd October 2011, 07:02 AM   #10
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
price/value?
Good list. Besides those I look for how it's going to work in the crossover and suitability for the intended application.
Correct driver choice is most important and get it right and you're more than half way there. Get it wrong and can end in tears.
Your way to choose driversHide this!Advertise here!
What to choose?! rinx Multi-Way 12 29th September 2007 10:23 PM
Help me choose please fighi77 Tubes / Valves 12 10th June 2007 01:35 AM
3way idea,help choose drivers peterpan Multi-Way 1 11th October 2005 12:47 AM
How to choose 15" drivers for QSC 2450 amp? lunchmoney Multi-Way 9 5th May 2005 06:40 PM
What to choose ? ToG Chip Amps 20 16th November 2004 02:36 PM
Copyright ©1999-2017 diyAudio
