Hi all,
I would like to keep this first build as simple as possible..... but not too much. At first I was going to find some designs that have been tried and tested but I cant help but wanting to do my own the way I want with the components I want. All in all I've been aiming at a DIY build of the Swans M1 Swan M1 DIY buuut the builder says it costs him $550 per pair..... and I've seen the Swan M1s from $450-500 on Audiogon so I kind of decided not to go with those but something close. I also wanted to have a better base from the monitor. I have been looking long and hard and I have been aiming at HiVi's drivers and their speakers. One of my coworkers has Swan Diva floor standers and they used the T28 tweeter and Their Magnesium (golden looking) drivers and it sounded really good, but I felt it was to high or metal like or a bit edgy but with really good bass (midrange). I want a really clear monitor speaker that delivers good image and it can dissapear from the room and can still pack a good punch here is what I have been looking at. Tweeters: Bohlender Graebener Neo3-PDRW Planar Tweeter $57 Datasheet Hi-Vi RT1.3WE Ribbon Tweeter $37.85 Price and freq response Woofers Hi-Vi L6-4R 6" Woven Kevlar Cone - 4 ohm $39.25 Price and freq resp Hi-ViF6 Bass-Midrange info and freq resp The L6-4R is used in Swan's higher end speakers M3 spec here and some version of the RT1.3 tweeter. Those woofers and tweeters are also used in the M6F and the RM600F list of models Right now I am looking at using Hi-Vi L6-4R for the woofer and the Hi-Vi RT1.3WE Ribbon Tweeter. The responses on these two drivers seem very flat and nice compared to other's I've seen. Can they work together or the crossover is going to be a pain? honorable mention: Hi-Vi RT1C-A Isodynamic Tweeter, 120mm, 94dB here Hi-Vi M6N Bass-Midrange Overview of M6N Drivers_HiVi,Inc |
#2 |
i figure a budget for $300 with making my own enclosures?
#3 |
any thoughts?
#4 |
Hi .
I really enjoyed the sound of a isodynamic tw ( Infinity's ) for a few years . They are likely to be crossed at a 2nd order slope ,minimum . Those Hivi tw are medium-high sensitivity , so they'll need some attenuation , as little woofers usually don't get over 90 dB , before the crossover , so after it and on the baffle they will exhibit even -3 dB !! But that's not a problem ,since resistors are the solution to bring down tw's sensitivity . |
#5 |
I strongly recommend against doing your own thing for your first build.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#6 |
For a first build, perhaps try a full range driver design. 1 good quality speaker driver won't cost much.
Initially do not use filter components at all, and later you can experiment adding a few corrective components. For example, while I've not heard it myself, the MarkAudio Alpair 10 is said to be quite excellent in small boxes such as the one you're aiming for. Or, if you would put these compact speakers on stands, then you can just as well build a floor stander, for example a backloaded horn using an 8" Fostex FE206E speaker. The above two suggestions may seem quite exotic, yet many people are happy with such configurations. Last edited by talaerts; 27th October 2011 at 06:07 AM. |
#7 | ||
This will be just at the end of the L6-4R. Can be done. It would be nice if the tweeter can be crossed lower at 2,000Hz. This will allow some room to locate the sweet spot. Quote:
I just bought 4 pieces of M6a. I believe the M6N is somewhat similar. They are meant for 3-way.
AmpsLab.com |
#8 | |
As mid woofer what do think of this aluminium cone of peerles. Cross it second order 1800Hz 1,2mH 8,2uF(for the ribbon a superior Z Janzen). With neo3 used as dipole with a 3Ohm series resistor. So you get a 8Ohm 88db 1wmtr loudspeaker Peerless 835025 6-1/2" Aluminum Cone HDS Woofer 264-1086 pdf this driver offer great linear extrusion over 5.3mm. -6dB 30Hz. http://www.tymphany.com/files/HDS-P835025%20Rev2_0.pdf ![]() Alu cone wil combine good with the ribbon (I have a set of Swans RT1 wasn't better then the titanium 1" dome dsm25ffl I already had) Crossing a ribbon isn't hard it is a nice flat impedance the woofer would need a compensation to control the rise of resistance HF. Then use a 4.7uF capacitor in series with 8.2Ohm parallel to the woofer. And at 7kHz we make a zobel 5.6uF bipolar and a 0.1mH coil in series you can ad no resistance or up to 8Ohm until you like it the zobel is also parralel to the woofer voice coil.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 27th October 2011 at 05:51 PM. |
#9 |
I would not mind if in your first build the XO isn't right if you bought good drivers you can always change the filter when you know better. Or build something new with your old drivers closed,BR,TL.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet |
#10 | |||||
- also i would need to adjust the impedance no? Quote:
- I will be simulating everything before the build. I dont want to measure but I will use the Manifacturor graphs for the SPL and Freq resp to design the xo and box. Quote:
-I have been looking at this tho Tang Band W8-1808 8" Neodymium Full Range Driver and it looks impressive but I would like to make it a floor stander like the Zu Druid but I dont know if it will have enough punch and if i will be able to make the right chamber/cabinet for it because i've seen some pretty complex designs..... or I just need a box with braces and a port? If it is a full ranger I wouold like it to be floor standing up to my chest I guess. Quote:
-nice link btw, tnx Quote:
-3kh high freqency is hard to cross, no? the Neo3 can handle it i guess. I like the low frequency but I dont know if the aluminium will give more metallic sound? -I would like to see some reviews on the Peerless or in what speakers it is used. - I will have to look into that driver |
| Trouble selecting drivers | sun850 | Car Audio | 1 | 25th October 2010 11:52 AM |
| selecting drivers | iceblueorbitz | Multi-Way | 4 | 16th June 2006 10:45 AM |
| UCD400 Build-Need Help Selecting Components | 14U2NV | Class D | 3 | 11th May 2006 02:44 AM |
| Need help selecting between two budget 10" drivers | percy | Multi-Way | 3 | 16th March 2005 10:28 PM |
| My Loudspeaker Project: a 2 way transmission line. Phase 1: selecting drivers | Bricolo | Multi-Way | 58 | 17th June 2003 08:13 AM |
| Page generated in 0.14359 seconds (84.47% PHP - 15.53% MySQL) with 11 queries |
