#2 |
A quick google search for "polypropylene glue adhesive" reveals lots of different adhesives that work, few of which will probably be available in small quantities.
May be cheaper to go to a re-cone shop that stocks the stuff (it has a short shelf life)and have them do a little dab. I just waited over a week for some 3M 5002 to cure on my polypropylene Foldbote, and it is not sticking, a slight bend and it separates :^(. Which I had done the Google search for "polypropylene glue adhesive", rather than Foldbote transom repair... Art |
#3 |
just a thought if perfection is not required...could it be welded back together?
Maybe have a friend hold a small metal block on the back side of the cone, and gently heat weld/fuse the floppy broken edges back together, maybe with a heated metal rod with a flat end. It won't look pretty, but it would not change the overall mass, and hopefully keep the broken edges from buzzing. good luck! |
#4 | |
The polypropylene bottle material could be cut into a thin strip and used as a welding rod. |
#5 |
Probably $40 to replace the driver. Bite the bullet.
#6 |
#7 |
Speakerholic
Not sure what it costs but here's some designed for priming the surface before you add a 'super' type glue. I would do it on the back and add a piece of bathroom tissue as a scrim.
PASCO FIX Industrieklebstoffe |
#8 | |
#9 |
I'm willing to bet that that damage is more cosmetic than performance related. A small dab of a gooey glue to seal the air hole is all you need. The only problem is getting something to stick to polypropylene.
Polypro primers as mentioned above. I'd be tempted to cut a nice small circle of black masking tape and put the grilles back on. David S. |
#10 | |
| Precision Power pc450 Fixable? | Wigsplitter | Car Audio | 9 | 4th October 2011 10:56 PM |
| Burned T-amp fixable? | jaste | Class D | 1 | 8th November 2007 08:38 PM |
| Fixable or Not? | sschoeffler | Parts | 3 | 11th November 2005 04:52 PM |
| is my amp fixable??? | muskgrave | Car Audio | 1 | 11th April 2004 03:08 AM |
| Page generated in 0.10265 seconds (80.15% PHP - 19.85% MySQL) with 10 queries |
