Are you (open) baffled yet?
Old 29th April 2004, 08:55 PM   #301
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
In a 3way OB setup, is it necessary to isolate the bass driver? If so, how deep should the separating board go?
I ask this because I had a few different drivers on a test baffle to get a feel for their bass response. I connected 1 at a time, but realized that during the test the unconnected driver cones vibrated quite alot. I had to put boards over them because they changed the response. That made me think what kind pressures are put on the midranges while everything is in use and maybe go unnoticed.
Everyone has a photographic memory. It's just that most are out of film.
Old 29th January 2006, 04:24 PM   #302
talatnat is offline talatnat  Thailand
Default The X-baffle (OB) spreadsheet
I was running some numbers through the spreadsheet, and am hoping somebody could clarify a momentary point of confusion:
Are the distances from the 1) floor 2) back wall 3) and side wall measured from the driver's center or from the edges of the baffle itself? It's not clear in the spreadsheet's wording, especially since one has to specify the baffle dimensions prior to inputting these distance parameters.
One might presume it's from the edges of baffle, but then what if one added wings (as the OP did), or angled the baffle surface up or down? Also, if one were to hang a long OB hanging equidistantly (or not) from the ceiling and the floor, is it possible to account for the effects of the second surface (either ceiling or floor, since we specify only one distance in the spreadsheet)?
I'm dense, and sorta baffled.
Thanks in advance.
Old 29th January 2006, 05:57 PM   #303
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
All those distances are for the driver. The calculations regarding the side wall distance will be severly compromised if you add folded back wings. Rear distance will work everytime. Hight above floor assumes the OB standing on the floor. Lifting it up will be a completely different set.
All IMHO.
Rudolf
www.dipolplus.de
Old 19th March 2006, 08:40 AM   #304
peterbrorsson is offline peterbrorsson  Sweden
Hi, for those that haven't got woodworking abilities, check this out for baffles. Sold beech with an oil treatment!!
Cheers
http://www.ikea.com/webapp/wcs/store...64*16225*15876
Old 19th March 2006, 10:20 AM   #305
Landroval is offline Landroval  Finland
And this:
http://www.ikea.com/webapp/wcs/store...00*16476*16477
The edge reflections wont be a problem because of the shape
Old 19th March 2006, 01:46 PM   #306
MBK is offline MBK  Singapore
They have a couch (coffee) table too (couldn't find it on the swedisch site, here from the Singapore site ) that would fit perfectly.
The parts are bent plywood, as for a folded baffle, with wide radius, and size is almost perfect.
Old 20th March 2006, 08:26 PM   #307
HI,
These speakers could be interesting in an open baffle. Tommy,from Hifi Kit, said he doesn't have X-max or freq. response
but for this price, there might be a possibility for me to try them. If time allows
Old 25th March 2006, 06:40 PM   #308
Hmm, it seems that it is not possible to attach the web page. Search for www.hifikit.se and Rila BW1202
Old 19th March 2009, 04:16 PM   #309
Telstar is online now Telstar  Italy
Originally posted by Kuei Yang Wang
I believe the biggest problems with open baffles are peoples prejudices and stupidity. As with all things that are problems, actually.
I had to requote this gem
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 24th August 2010, 03:03 PM   #310
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Folks,
Originally Posted by catapult View Post
Got any measurement curves yet?
That was a question in around 2003 at the beginning of this meta thread directed at this speaker:
http://www.diyaudio.com/forums/multi...tml#post234860
Doing some ego browsing I noticed a review in a really odd corner of the web (Anandtech) by Rajinder Gill that included measurements of both the naked Baffles and of a system with a subwoofer.
The whole article is here and makes very interesting reading;
AnandTech.com - Audiophile Journeys with a PC
Included are the in-room responses of the open baffles (fitted C37 lacquered Supravox Bicone Signature Drivers) on their own, showing the naked in room response in that specific room:
Please note that this response is not smoothed a lot and taken at a single point and includes the extra HF rolloff from a non-oversampling DDDAC with TDA1543 AND a Welborne Labs Yota 300B Amplifier.
For comparison here the responses of two expensive commercial speakers in one particular writers room with a fair bit of smoothing and spatial averaging (this was the first graph I found on SP's site, no specific criticism etc of the two speakers intended, just a comparison datapoint)...
So anyway, now there are some measurements, thou maketh of them what what thy may.
Ciao T
Are you (open) baffled yet?Hide this!Advertise here!
Baffled by a UPS analog_sa Parts 2 21st June 2008 06:34 PM
Open Baffled 3.5 TMMW or MTMW? Emiel Multi-Way 5 16th March 2006 05:09 AM
open baffled all over again then_dude Multi-Way 58 5th April 2005 10:42 PM
5" enclosed or 6.5" open-baffled coolkhoa Multi-Way 6 17th May 2004 03:18 AM
Passively baffled jmiyake Multi-Way 0 3rd February 2003 11:26 PM
