Are you (open) baffled yet?
Old 7th September 2003, 06:30 PM   #11
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Default Listening impressions and positioning
Wow, I didnīt realize you had them already "burnt in".
Can you tell us some more about their imaging qualities? Your baffles are quite close to the corners - my own selfmade OBs would require much more distance to the front wall for optimum sound quality. Have you played with other positions in the room? And how wide is the area for pinpoint imaging in your listening position?
As you will already have noticed, Iīm really eager to know more about the Prometheus. Thanks for your patience in advance.
Rudolf
www.dipolplus.de
Old 7th September 2003, 06:54 PM   #12
Stew320 is offline Stew320  Shetland Islands
Send a message via MSN to Stew320 Send a message via Yahoo to Stew320
Wow, those look nice!! The solid wood board looks the part.
Thats one hellava nice system you got there
Stew.
Old 7th September 2003, 10:44 PM   #13
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Konnichiwa,
Originally posted by Peter Daniel
What's the approx crossover point to the tweeter?
The tweeter rund with around 13KHz -3db point, but it has a slightly falling response between 10KHz & 20KHz so will likely be a little lower acoustically.
Stew.
Thanks, on both counts. The boards are from Ikea for < $ 40 each....
Sayonara
Old 7th September 2003, 10:52 PM   #14
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
I use solid birch for my open baffles, I find solid wood with a stain is perfect for OBs, you get a beautiful front as well as interior. Nice job again Kuei.
Old 7th September 2003, 10:57 PM   #15
Bricolo is offline Bricolo  France
Bricolo's Avatar
I hope it's a bottle of french wine, on the last picture
Old 7th September 2003, 11:10 PM   #16
Romy is offline Romy  United States
Banned
Kuei Yang Wang,
I have found a pair of the drivers that I have been searching for a long time with attempt to build something similar that you did. (Although I never thought that in order to be really baffled the divers could sit in so small enclosure) I am kind of horns guy and know a little about the open baffles, however the certain uniqueness of my prospective open baffle projects and my love to the way in witch the open baffles sound force me to be interesting. So are any Web sources that you might suggest with the calculation of the open baffles?
Thanks,
Romy the Cat
Old 7th September 2003, 11:19 PM   #17
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Le vin est un Chateau Bricolo d'un excellent millesime..j'ose esperer.
On a more serious note, alot of credit should go to Steen Doessing of SD acoustics for bringing both OB design and bi/tri wiring back to our attention.
I've owned a pair of OBS2 by SD Acoustics and would like to point to the importance of proper baffle design.
The baffle should be made asymmetrical IMO to reduce IMD.
Steen designed an OBS threeway which I can recommend to anyone.
It comprises a bass-reflex rear firing port woofer, the OBS midrange and a ribbon tweeter by Visaton.
A very good speaker indeed...room placement is as critical as it would be for any other dipole.
Some really nice stuff you have there, TL.
Frank
Old 8th September 2003, 11:53 AM   #18
fdegrove's Avatar
Here's one I particularly like:
PHY
Frank
Old 8th September 2003, 12:08 PM   #19
Banned
Thanks, Frank
Unfortunately I do not see there what I need. As I understand they just push their drivers and pre-caned enclosures for them. I do not particularly care about their drivers and consequencetualy about all their enclosure logic. All that I would need would be a simple calculation between the dimensions of the baffle and the desirable LF roll-off..
Rgs,
Romy the Cat
Old 8th September 2003, 12:14 PM   #20
phase_accurate is offline phase_accurate
Is that a Beauhorn in the background ? How does it compare to your open-baffles ?
Charles
Are you (open) baffled yet?Hide this!Advertise here!
Baffled by a UPS analog_sa Parts 2 21st June 2008 06:34 PM
Open Baffled 3.5 TMMW or MTMW? Emiel Multi-Way 5 16th March 2006 05:09 AM
open baffled all over again then_dude Multi-Way 58 5th April 2005 10:42 PM
5" enclosed or 6.5" open-baffled coolkhoa Multi-Way 6 17th May 2004 03:18 AM
Passively baffled jmiyake Multi-Way 0 3rd February 2003 11:26 PM
