Trying to find a suitable speaker design in here is hard, there is so much choice.
I think what could help is to create a thread where every diyers: 1-Name all the projects you have done 2-Name your favorite project. This could be a good reference Cheers |
#2 |
If what you want is "trying to find a suitable speaker design", such a list could probably confuse you more.
For myself, the answer would be: 1. quite some 2. the latest No offense, that doesn't say anything I know. But I guess some 'names' following those answers don't help much, either. Find out what you want and start from there would be a better way. |
#3 |
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#4 | |
Im aware of that. thats exactly why I ask for experience diyers. Oh well... |
#5 | |
a) Pick blindly, not knowing what it is that you want. b) Educate yourself about the product technology, audit as many examples of it as you can, then set your own criteria and budget for what it is that you want. Now you are ready to pick it and then shop for it wisely. Your success a) will require lots of luck, little effort, and will probably remain elusive. or b) will require and deliver the opposite. As you can guess, your most favorite project should always be b) as well. Regards, WHG |
#6 | |
1)Closed with fulrange Karlson enclosure 3way horn Bas reflex 3 way Two way active backloaded horn titanium drivers 3way bandpas with bandpas low monitor. Two way D'Appolito transmission line Basreflex D'appolito 3 way carbon cone lowHigh-end 3 way dáppolito with aluminiumcone Bandpas D'apolito 3 way big bandpass The fatboy 2 way basreflex bookshelf 2way backloaded horn 102dB 1Wmtr.Project presentation Horn Almighty 2way basreflex lowmid horn midhigh 92dB 1Wmtr Project: monitor-XL reference values 2way kugelwellenhorn mid high, OB low mid.Kugelwellen Horn. And some experimental boxes to test the result. 2) Bandpass D'appolito.big bandpass The fatboy
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 18th October 2011 at 07:56 PM. |
#7 |
on the cheap, am fond of a 1-4'x8' sheet 18" woofer Karlson-coupler topped with a slotted waveguide - its steady state graph could probably improve by moving the baffle and reflector closer to the inside of the wings. Distortion at 30vrms is around 2-3%, very wide sound field, very little cone movement for output.
![]() a taller coupler turned out pretty good but I don't like its looks - the slotted wavguide pipe normally mounts inside the coupler above the 18" woofer- these play a lot louder than reflex with a lot less cone movement (imo) ![]() Helmuth's fatboy approach looks cool Last edited by freddi; 30th October 2011 at 09:53 PM. |
| Everyone has a favorite what's yours? | bigfishe | Full Range | 50 | 23rd March 2011 04:01 PM |
| Cult movies - what is your favorite - what is your favorite part | Ken L | The Lounge | 243 | 15th February 2010 04:09 AM |
| My favorite preamp | 7n7is | Tubes / Valves | 13 | 30th March 2008 02:51 PM |
| Favorite drivers | Jean | Multi-Way | 2 | 23rd April 2007 09:42 PM |
| favorite recording... | sberube | Music | 1 | 27th June 2004 04:55 PM |
| Page generated in 0.10087 seconds (79.45% PHP - 20.55% MySQL) with 10 queries |
