I will soon need a system of loudspeakers for my 15W SET amp. And want to get some performence in the lower octavers as well, even if this means using a SS amp.
But were to crossover. In order to have a decent SPL i will need horns i think. The most simple solution i am considering, is this: A full range speaker(3 to 5 inches), horn loaded with a tractrix horn(have one-it goes to 170hz) and 2 pa drivers (12 to 15 inches each) for the lower octaves. But this means i will croossover at 300 hz. This i don't like. Any other solution? |
#2 |
Nothing wrong with a crossover at 300Hz. I'm an octave higher and it sounds fine.
What SPL do you need or desire? Have you measured in your room when it's playing loud? And how big a speaker do you want - can you tolerate? |
#3 |
Under 600 you use a solid state? That would be a good thing. At 300 i will have no problem crossing over to the SS
| Solution Needed,,,Quickly! Remote Leads for Both Amps Not Working! | 19EDR | Car Audio | 1 | 4th April 2011 07:09 AM |
| Simple Octal SET help. | forsakenrider | Tubes / Valves | 23 | 21st March 2011 04:27 PM |
| Need a solution for two amps and one set of speakers | maurycy | Everything Else | 2 | 26th October 2007 01:48 PM |
| Simple EL34 SET; advice? | audio_moksha | Tubes / Valves | 11 | 29th November 2006 03:58 AM |
| Recommendations for Simple SET Amp Topologies | Oborous | Tubes / Valves | 15 | 19th February 2005 12:03 PM |
| Page generated in 0.07196 seconds (72.75% PHP - 27.25% MySQL) with 10 queries |
