Old 15th October 2011, 04:53 PM   #1
NYCOne is offline NYCOne  United States
Default Rectangular waveguides - what are they really?
I came across the Beyma WL-5:
http://www.lautsprechershop.de/pdf/beyma/beyma_wl5.pdf
and the BMS 4510ND
http://bmsspeakers.com/fileadmin/bms...0nd_curves.jpg
I realize these are designed for stage line arrays, but with such coverage at the various angles, wouldn't these make great home drivers?
If so, they all refer to 4"x1" waveguides or horns. What are such beasts? I have not been able to find an example. Are they simply 90 degree boards used as waveguides?
Old 16th October 2011, 01:49 PM   #2
gedlee is offline gedlee  United States
The waveguides for these devices are usually custom and part of the actual enclosure with the Mid range divers built into the side walls of the waveguide. I don;t know of any one who sells just the waveguides.
Old 16th October 2011, 03:37 PM   #3
Default Just a Necked Driver ...
and the BMS 4510ND
... it is not a complete horn,
Here is the horn mouth part, Beyma TD-WL4 that receives a pair of WL-4 necked compression drivers. The WL3 and WL5 are parts for similar arrangements
WL4
http://profesional.beyma.com/ingles/pdf/WL4.pdf
TD-WL4
http://profesional.beyma.com/ingles/pdf/TDWL4.pdf
TD-WL5
TD-WL5 :: ELMUZ & BEYMA PL
Cannot find this on the Beyma web site.
WHG
Old 16th October 2011, 03:46 PM   #4
Pano is offline Pano  United States
Pano's Avatar
Impressive graphs on the TD-WL5. Even the distortion is down -25dB (H2) and -45dB(H3) at 110dB. Of course that's two drivers on the horn.
Old 16th October 2011, 04:53 PM   #5
If you have an example in a photo, I'd love to get an idea of how these are used.
Old 16th October 2011, 05:49 PM   #6
Pano's Avatar
They tend to be used like this: MILO
They will be stacked a few units high. You can see why they have a narrow vertical pattern.
I don't know what drivers are used in the MILO, though.
Old 16th October 2011, 07:15 PM   #7
Default Example with Drawing
See
http://beyma.com.ua/downloads/LARBEYMA%20.pdf
WHG
rectangular - round port? ThyDntWntMusic Subwoofers 7 25th August 2011 11:57 PM
Baffle Step on non-rectangular Baffles jmacmythtv Multi-Way 8 2nd February 2009 07:00 PM
Narrow, shallow rectangular port cabbagerat Full Range 7 14th February 2008 10:03 AM
Port question, round vs rectangular kvk Full Range 6 11th February 2008 08:16 AM
rectangular port questions Jimmy154 Multi-Way 8 30th June 2002 08:37 PM
Page generated in 0.09790 seconds (79.90% PHP - 20.10% MySQL) with 10 queries
