guys please help, i have the konzert speakers w/ 450 W and im wondering why is the other speaker is in very low tune.. is that the real thing? i've noticed that the other has a lessen bass sound while the other has almost the bass itself, just wondering if this is ok or should the 2 speakers (pair which is left and right) must have the same sound plss. help me bout this matter. thanks
Yes, you are right. If they are a pair, they should have the same sound. Unless they were repaired/second hand/or over-heated. You should diagnose the problem if it's from the crossover? or from the speaker driver. You can check changing components between left and right speaker. Check first is not your Amp, doing the same with the left and right speaker (trading sides) and cables.
