Foil inductors, stray capacitance?
Old 14th October 2011, 04:44 PM   #11
Mark.Clappers is offline Mark.Clappers  Netherlands
Mark.Clappers's Avatar
Originally Posted by Conrad Hoffman View Post
IMO, you won't find any great difference in practical performance between a cheap hand wound 0.15 mH inductor made of wire and a boutique foil component. Also, I'd never buy a foil inductor from anybody that wouldn't tell me the Q and the self-resonant frequency up front without having to buy the thing and measure it.
Professionally I wouldn't either, but as this is a hobby and I like experimenting with these kinds of things it's not a problem. Especially the very low DCR of this coil is interesting for me. I want to use it to make a notch to control the resonance of a mid bass driver, the rest of the system is fully active (Samson 3 way x-over 24dB LR + modified Behringer DEQ2496 and a bunch of LM3886 based amps).
This setup is already working very nicely with a Seas U18RNX/P woofer which doesn't require a notch. (tweeter is a ScanSpeak version of the XT25) I know I can also make the notch part of the active circuitry but this would require (a lot) more effort.
I have experience in designing filters for TV applications (mainly IF filters) so a notch filter for audio frequencies shouldn't be a problem. That is, if all the data is available...
Anyway I am rambling, thank you all for your input!
Music is art - Audio is psychoacoustics & engineering
Old 14th October 2011, 04:54 PM   #12
Conrad Hoffman is offline Conrad Hoffman  United States
A man after my own heart- after all, measurement is fun! FWIW, I've also seen improvements at certain values and frequencies by winding coils with the right Litz wire.
I may be barking up the wrong tree, but at least I'm barking!
Old 14th October 2011, 11:16 PM   #13
AllenB is offline AllenB  Australia
Speaker inductors are practically close to the ideal component. If you are curious, put some resistance (0k1 -10k?) in series with the winding and sweep it (maybe into the low MHz range) watching for the peak, preferrably on a scope. I wouldn't bother with the smaller values like this one.... mains transformer primaries usually show this peak, often near the upper audio band. This is where I usually use this test either when damping the windings of a power transformer or finding suitable output transformers.
You can then back calculate an approximation of the capacitance...I'd be reluctant to rely on a meter due to the nature of the lumped strays.
Foil inductors, stray capacitance?Hide this!Advertise here!
Shunt/Stray Capacitance starz00700 Planars & Exotics 3 3rd July 2010 12:32 PM
Stray capacitance of CCS zigzagflux Tubes / Valves 1 29th April 2008 01:59 PM
Stray capacitance in audio circuit ? gaetan8888 Solid State 8 10th June 2007 06:38 AM
Foil inductors in Australia? xephon Parts 3 30th September 2006 03:58 PM
Connecting foil inductors dublin78 Multi-Way 2 29th June 2006 08:53 PM
