Old 13th October 2011, 02:24 AM   #1
Einric is offline Einric  United States
Default Resistors for BSC
SO, does it matter what type of resistors you use in the BSC so long as they are non-inductive.
Would many parallel higher value resistors of the standard carbon type be acceptable so long as your wattage value is met?
Would 20W film resistors be good?
What is the best type of resistor to use?
Old 13th October 2011, 05:58 AM   #2
AllenB is online now AllenB  Australia
It is not that critical. There are differences between types but the power rating is most significant here. Stray inductance is almost irrelevant in this position.
5 Watt Resistors on Aleph 4 and Holco Resistors nicharis Pass Labs 16 8th February 2012 07:50 AM
FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers chris-man Swap Meet 1 28th May 2009 11:47 AM
FE107E and BSC PeterPalmer Full Range 0 3rd May 2009 06:36 AM
BSC help flippinjaz Full Range 1 20th February 2009 02:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
