Line Arrays - Page 4 - diyAudio
Old 30th January 2002, 04:34 PM   #31
Bill F. is offline Bill F.  United States
Bill F.'s Avatar
Dave,
I've heard that curved baffles work very well--with one big caveat: the sweet spot is focused into a tiny area defined by the curve of the baffle--sorta like a pair of virtual headphones hanging in space.
At that special little point, time coherence is excellent since all drivers are equidistant from your ears. Since the array is focused, you're also probably beating the 3dB decay rate of a perfect line source. The apparent efficiency (spl) of the array will be magnified, basically beaming its energy straight into your earholes.
Step forward, behind, or to the side of this zone, and all bets are off.
Bill
Old 30th January 2002, 07:08 PM   #32
Bill,
Thanks for the reply. I guess I'll have to make a separate set of "regular" speakers in case others are listening.
Dave
Old 8th February 2002, 07:32 PM   #33
Won is offline Won
In the 7 (really 6) speaker bessel array, two sets of speakers (the closest and furthest pair from the center) are out of phase. What if these pairs were made to share an enclosure? I suppose their response would be similar to an infinite baffle. Is the infinite baffle a good alignment for speakers of Qts of 0.47? I could probably raise the Q to 0.5-7 by playing with the amplifier output impedence.
Thanks, Won
Old 10th February 2002, 10:20 PM   #34
frugal-phile(tm)
planet10's Avatar
Originally posted by Bill F.
One thing I do wonder about is comb filtering in line arrays.
I have had this paper "The Line-Source Loudspeaker and its Applications" by Paul H Taylor from 1963 and have finally completed conversion from paper to pdf.
Some mathematical analysis, with some very illustrative pictures of comb filtering, and some practical applications.
Line-Source paper by P Taylor
dave
NSB line arrays for PA use? Spasticteapot PA Systems 1 1st April 2007 12:32 PM
Do line arrays... LizardBrain Full Range 4 23rd March 2006 05:21 AM
Line Arrays Down Under deaf monkey Multi-Way 0 14th December 2004 06:03 PM
Power for Line Arrays ralph-bway Multi-Way 4 27th February 2004 06:20 AM
physics of line arrays Craig Multi-Way 9 10th November 2003 04:00 PM
Copyright 1999-2017 diyAudio
