"Tired2way" speaker building.
Old 29th October 2011, 04:11 PM   #81
Starre is offline Starre  Sweden
OK, I do not have a buss bar, do you mean one wire to every component from common, Salas?
Old 29th October 2011, 04:12 PM   #82
Lol Toaster, I am new to this so take it easy with me :P.
Old 29th October 2011, 04:16 PM   #83
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
''Buss bar'' is the concept. Common in old tube building. Check out a Jadis amp guts photo on the web to picture it for instance. Could be a thick wire. The idea is you progressively tap along the ''bar'' from lighter to heavier current points and you ground at the end. Say in this case you stick the tweeter (-) then the woofer (-) then the conjugate (-) then the amp (-). So heavy currents don't mix with lighter ones.
Old 29th October 2011, 04:25 PM   #84
Ok, but the main thing with star earthing is that all negative points from components is soldered in the same physical point with no wire inbetween them? They originate from the exact same physical point to aviod any hum?
Old 29th October 2011, 04:28 PM   #85
Salas's Avatar
There will be no hum in speaker level, that's in delicate signal electronics with PSUs around etc. But it will be cleaner for return currents. Either are good practices. Prefer the pure star if you can arrange.
Old 29th October 2011, 04:31 PM   #86
Interesting and ty for you impressive knowledge, I will give it another try tomorrow, I am meeting some friends tonight. Again, thanks Salas for your patience, it means alot to me hoping to get these nice speakers to play after all my/your efforts.
Old 29th October 2011, 04:38 PM   #87
Salas's Avatar
No problem, was no big effort. Yours really the effort. I wasn't expecting someone to pick up that one from a general discussion anyway. Wasn't meant as a building suggestion, but what the heck, nice try.
Old 29th October 2011, 04:47 PM   #88
Yes, I liked the idea of a 2-way with 8 inch woofer and since I am new to this you must start somewhere, and I would never be able to build any speakers without some help from more experienced people. I know it was not meant as a building suggestion from your part, but I liked what you and your friend came up with.
Old 29th October 2011, 04:52 PM   #89
Salas's Avatar
Will you brace front to back also? The original has two crosses.
Old 29th October 2011, 05:12 PM   #90
Yes I will do that, the braces are ready to put in place when I finally glue the baffle into place. I will have one inbetween woofer and tweeter and one just below the woofer. I will show a picture later on and you can see exactly.
Have a nice evening, bye for now.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
