"Tired2way" speaker building.
Old 3rd April 2013, 09:28 AM   #871
schmutziger is offline schmutziger  Abu Dhabi
Originally Posted by Starre View Post
Me and a friend was listening this weekend and he said he missed some of the clarity from his speakers mid range. Is there a way to maximize mid range clarity, how much depends on the driver itself and the cross over and speaker box?
First thing you should do is to listen to the speakers in the same room.
How do you know his speaker/system is the better one?
price/performance of ca22rny and D2608 is exceptional!
Is there any measurments/simulations of the speaker?
on and off-axis?
Old 3rd April 2013, 11:34 AM   #872
Dissi is offline Dissi  Switzerland
on and off-axis?
Here is a simulation:
The simulation shows indeed a little dip in the crossover region. After removing the 2.2uF capacitor in the woofer section it looks better:
However this kind of fine tuning is beyond the accuracy of the simulation. But you could try it and find out, if this modification improves the midrange clarity...
Old 3rd April 2013, 12:16 PM   #873
i dont think the dip is a negative thing, it is rather a feature
looks like dispersion issues in the 3-8kHz region
tweeter a bit high over 6kHz? attempt to get a nice energy curve?
Old 3rd April 2013, 01:12 PM   #874
Starre is offline Starre  Sweden
My own measurings does not show a significant dip around 2kHz and a rather even treble and the tweeter never sounds unbalanced beeing to high in level. I will try my friends cd-player to compare. Thanks for the post Dissi.
Old 3rd April 2013, 03:10 PM   #875
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Dissi, nice program you have made there. Set the mic axis between woofer and tweeter flanges for this one though, its the way it was made to stand against a listener at seated height.
Old 3rd April 2013, 03:27 PM   #876
ah, so it is not only the crossover you simulated?
Old 3rd April 2013, 03:38 PM   #877
Salas's Avatar
Its a made, measured, listened and tweaked to preference real speaker we made back then. Not just a sim.
Old 4th April 2013, 07:28 PM   #878
CD-player booked for a listening in about 10 days, back later with impressions.
Old 9th April 2013, 03:56 AM   #879
_henry_ is offline _henry_  Australia
what kind of cd player? any update?
Old 9th April 2013, 08:59 AM   #880
Audio Aero Capitole MKII. It is getting a little old these days but is still a vg cd-player. It is for sure better than my Naim CD5X.
I read a post on this forum that the coil used for the woofer in a 2-way can affect mid range clarity. I used this non-ferrite cored one: JANTZEN-2005 - Jantzen Wire non-ferrite cored coil 2,500mH 0,268Ohm 1,20mm - Europe Audio
Maybe a better coil increase clarity but I can not test this and they are expensive to buy.
I will report if a better cd-player makes a clear difference when I have tried it.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 09:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 05:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 09:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 03:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 17th September 2005 12:14 AM
Copyright ©1999-2017 diyAudio
