"Tired2way" speaker building.
Old 9th January 2013, 08:15 AM   #851
Starre is offline Starre  Sweden
Default Case closed for now.
I used some blu-tack between speakers and stands and plastic lenses about 1 cm in diameter under stands on my wooden floor on concrete and it sits very stable and the sound is dynamic and detailed without harshness. If someone wants to copy it I am happy to help with questions.
Old 9th January 2013, 08:37 AM   #852
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Final photo on shortened stands?
Old 9th January 2013, 08:54 AM   #853
Sure Salas, I will post tonight with the room as it is as well .
Old 9th January 2013, 05:40 PM   #854
Latest pictures, hope it is ok even if a little dark. Hard to get the right perspective on photo, it looks better in reality.
Old 26th January 2013, 11:13 AM   #855
Cut the panels to size and now it is all in place. Speakers are like I want them to be. I now can sit back an enjoy. The panels on the stands gives a llittle fuller bass which balance the mid range good. Posting pics of before and after shortening stands.
Old 26th January 2013, 01:19 PM   #856
Salas's Avatar
They look interesting from the front. Passing for floorstanders.
Old 26th January 2013, 02:29 PM   #857
Yes and I think they look good and more balanced now. From what I hear and measure it does not have any drawbacks using a panel like that. I am pleased with the sound and looks.
Old 26th February 2013, 02:40 PM   #858
Default Interesting test.
I visited a friend and listened to some music I know and also measured his speakers. I noticed that the amount of bass I have is quite balanced and in line with his Oscar Heil Kithara speakers (they do dig deaper with more power, though). I also noticed from measuring them in his room it had a slight mid range "hill" not very different from my speakers (centered around 500Hz). I think it has to do with the room itself. He has a very good room though with almost no bass nodes (we measured this too and no problems was found, very rare indeed). I listened to that norah jones cd and he had the same forward voice problem I had, even more than in my case, I think.
Old 26th February 2013, 02:50 PM   #859
Salas's Avatar
So there you are, nothing weird with your in room balance.
Old 26th February 2013, 04:11 PM   #860
Yes it is in order, wanted you to know about my findings.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
