"Tired2way" speaker building.
Old 17th December 2012, 08:20 PM   #811
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
How do you perceive it now?
Old 17th December 2012, 08:41 PM   #812
Starre is offline Starre  Sweden
Well it sounds very similar in my ears but it is better when I open that door since that bass peak is less. Maybe maybe a little calmer in middle range but I am not sure. I will try one last thing: trying to dampen walls with all stuff I can get on the walls and measure again, brb.
Old 17th December 2012, 08:55 PM   #813
Nah it did not work, looks about the same. It seems like that polyester wool is not very effective damping mids.
Old 17th December 2012, 10:07 PM   #814
Best to leave it for now, I get nowhere at the moment . And who knows, maybe most of it is room related after all. But they sound good with most music.
Old 17th December 2012, 10:31 PM   #815
Some good news: I listened to Norah Jones with headphones to compare with the speakers and I could actually hear some "shouting/hardness/forwardness" even with headphones in the same places as with the speakers. Last time I compared it was a big difference (old position of speakers in the other direction). My memory said it had none of that problem with headphones but it was actually there but since the difference was big I probably believed it had no "shouting" (wrong!) .
Old 17th December 2012, 10:33 PM   #816
Salas's Avatar
Always headphones are a good check.
Old 17th December 2012, 10:49 PM   #817
Yes, I feel a little stupid, but since it has a slight middle range hump I was fooled .
Old 17th December 2012, 11:10 PM   #818
Salas's Avatar
In wide angles above its pistonic range the 8inch is weak for dispersion. Letting it have bit more direct it offsets it somehow.
Old 17th December 2012, 11:33 PM   #819
I kept about half of that extra stuffing since It might have calmed it down a little and compensate slightly for my extra bracing stealing volume.
Old 17th December 2012, 11:37 PM   #820
Salas's Avatar
Slowing the velocity by damping is like expanding volume, yep.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 09:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 05:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 09:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 03:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 17th September 2005 12:14 AM
