"Tired2way" speaker building.
Old 16th December 2012, 04:50 PM   #791
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
P.S. If you take a measurement without the speakers playing, how it looks like for measuring system's and room own noise floor?
Old 16th December 2012, 04:57 PM   #792
Starre is offline Starre  Sweden
Well I probably had flatter in some but I made many measurings at and near listening position and they all had a similar level increase in the middle range. I think some near field ones looked flatter. I will try to put some more stuffing in and also wrap the extra bracing I put in with it and see what happens. If I am right too much stuffing can lower bass output and then the balance is wrong anyway. Yes I will post a measuring with the room noise, brb.
Old 16th December 2012, 04:59 PM   #793
Salas's Avatar
But do you perceive more than enough mids as it is?
Old 16th December 2012, 05:06 PM   #794
Here it is, noiselevel:
Old 16th December 2012, 05:07 PM   #795
Mids are a little too much sometimes on that Nora Jones CD I mentioned before but better after I moved the speakers to the other room direction.
Old 16th December 2012, 05:12 PM   #796
Also, the speakers are toed-in almost directly aimed at the listeningpos. so that trebel will not fall in level above 16kHz, maybe that beeming you mentioned gets noticed with that toe-in?
Old 16th December 2012, 05:23 PM   #797
Salas's Avatar
Too much residual in the measurement. Maybe you can still measure at higher SPL safely for Wattage when the speakers are playing? Try 5-10 degrees wider for toe in before doing something in the speakers themselves.
Old 16th December 2012, 05:29 PM   #798
Yes I will try that, back with results later tonight .
Old 16th December 2012, 08:42 PM   #799
Ok here it is, I boosted the level a little, hope it is enough.
First picture is as it was, then picture for picture the less toe-in it is and the last one straigt ahead without toe-in. It is the lined out top level that you should read. They all seem rather similar.
Old 16th December 2012, 08:55 PM   #800
Salas's Avatar
Hmmm... It could afford less mids as a pair at that particular point in space, looks like only the brilliance range tames with toeing out, but I am kinda worried of that bass mode that now the mids level meets. I mean the ear has the trait to lock on things in relief, and maybe if you will try drop the mids a bit it could suddenly start dragging. But all it takes is a trial as always. Do you have a circa 0.25mH coil to put in series to the bass driver?
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 09:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 05:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 09:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 03:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 17th September 2005 12:14 AM
