Old 28th October 2011, 09:55 PM   #71
Starre is offline Starre  Sweden
Hi Salas, I have started with the crossover, so far I have fixed the terminals and the capacitors soldered together (se picture). My thought is to keep all of the legs original lenght for now and later when I am happy with the layout and so on I will resolder it making it better looking (shortening the legs). I am making my first crossover so I am not familiar with how you do this the best way, but I am used to soldering things together. The capacitor "packets" will then be connected to other components using contact blocks with screws.
Old 28th October 2011, 10:03 PM   #72
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Looks like you are on your way. Look for best mounting the coils for minimum interference.
Old 28th October 2011, 10:07 PM   #73
Yes I have been reading about that so I will be careful, that wooden base I am using is rather big so I got plenty of space .
Old 29th October 2011, 02:25 PM   #74
Hi, this is my proposal for layout and connection, need some input thanks!
Old 29th October 2011, 02:34 PM   #75
Salas's Avatar
Make the common (-) like a star ground is better.
Old 29th October 2011, 03:03 PM   #76
You mean like this picture with a common "rail"?
Old 29th October 2011, 03:50 PM   #77
Toaster is offline Toaster  United Kingdom
In reply to post #70 Salas: No, that was the DBS6- I didn't get to build or listen to that one. The DBS4 was about 38 litres, so a bit smaller than the Tired, and used the SEAS 21FWB-M 8" paper mid-bass unit and originally the SEAS H107 (1"?) plastic dome tweeter. The MkII used the SEAS H253- I think- which was similar to the tweeter in the Mission 770 of the time. The MkII also had some crossover changes to suit the new tweeter and revisions to the bracing and internal foam damping. A particular feature was the use of drinking straws in the ports, in the manner of contemporary Celef loudspeakers. My brother still uses DBS5s, which were 7 litre closed boxes using the KEF B110B and the Scan-Speak D2008 tweeter. The later DBS7 was built by a friend of mine to replace his own DBS4s, which were stolen. That was a slim floorstander using one of the variants of the Audax HM170Zx aerogel cone mid-bass units and the Morel MDT30 tweeter, reflex loaded. IIRC there was also a DBS8 which used a SEAS coaxial driver and, I seem to remember, a second SEAS bass unit in a sealed box. All the ones I heard were very good. The DBS5 was printed in Practical Hi-fi in the early '80s, with the rest published in Hi-fi News. Dave now works for Epos as head of speaker design. Well you did ask Salas! More information than you wanted no doubt! Anyway, the Tired strongly resembles the DBS4, in outline at least. It's all in the execution though of course. And now we return to the focus of the thread...
Old 29th October 2011, 03:55 PM   #78
Ideally Starre, they would all be brought together at one point. Starre earthing?
Old 29th October 2011, 03:55 PM   #79
Salas's Avatar
That's a buss bar, quite good if the bar is thick. Also practical because in line.
Old 29th October 2011, 03:59 PM   #80
Salas's Avatar
Originally Posted by Toaster View Post
In reply to post #70 Salas: ...
Thanks for the detailed answer. The Tired was born out of pure necessity, nothing ambitious. The old cab dictated it basically. Still in service with my friend though.
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS. Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Copyright ©1999-2013 diyAudio
