"Tired2way" speaker building. - Page 78 - diyAudio
Old 6th December 2012, 10:23 PM   #771
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
100-200Hz in most stand mounts, detracts from music fundamentals. Hence Roy Allison's countermeasures in design concepts. You need double mattresses thick stuff on floor or kid sized anechoic wedges to stop such stuff unfortunately.
Old 6th December 2012, 10:34 PM   #772
Starre is offline Starre  Sweden
Ouch :, not easy to implement then. I had a look at your posted measuring of the speakers and it also show that peak at 50-60 Hz. This should be a standing wave between floor and roof I think, since f = 343/2x2,5 gives f=68 Hz with a height of 2.5 m in room. To be correct the speaker would be directly at floor level, and with speakers it is never so in real life since it is away from the floor, maybe this is why the peak is a bit lower than 68Hz?
Old 6th December 2012, 11:02 PM   #773
Salas's Avatar
That is why subs are on the floor where ever possible in gigs when point source satellites or line arrays hang like bananas. Also in column speakers that are 3 way, the bass units make half space to floor and mids cross away from their first reflection wavelength to lows as per Allison for those following.
Old 6th December 2012, 11:19 PM   #774
Ok, It also came to mind that if you try different stands height it can lower a standing wave peak a little since its amplitude is at maximum in the middle between floor and ceiling (lowest mode), but if you put it as close as possible to the floor it gives other problems. Maybe a low speaker tilted upwards is good to get the woofer closer to floor level?
Old 6th December 2012, 11:44 PM   #775
Salas's Avatar
Subs and sats and 3 or 4 ways help have basses low and mids at seated ear height. Stand mounts are usually very nice but suffer floor cancellations.
Old 6th December 2012, 11:48 PM   #776
Salas's Avatar
Old 7th December 2012, 12:22 AM   #777
Joachim Gerhard's Avatar
This was even more extreme :Snell Type 1 Crossover Rebuild
I heard it ones in a big room in the late 70th. To my surprise it worked but i was quite far away. Maybe 3 meters or more.
Old 7th December 2012, 12:25 AM   #778
Salas's Avatar
To wedge and to reflect.
Old 7th December 2012, 01:06 AM   #779
Peter Snell had a lot of innovative ideas. sorry that he passed away so early.
Old 7th December 2012, 01:07 AM   #780
Was not a big success on the market though but maybe i will try something like that sometimes. I think it needs a rather big room tough.
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Copyright ©1999-2017 diyAudio
