"Tired2way" speaker building.
Old 18th October 2012, 07:30 PM   #721
Starre is offline Starre  Sweden
Yes it is. It says 16 bit 48000. The guy from XTZ said it should be 24 bit 48000 but that option is not possible on my computer so I took the best possible.
Old 18th October 2012, 07:52 PM   #722
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Lets see what you will get when you will set the speakers up across the other room dimension then. But show us pictures of the system in room and where the mic stands for each vertical bar graph, noting if its one or two speakers playing if you can, this diy speaker thread came to include general education qualities about cabinets, in room sound, basic assessment etc. in a simple form real situation, which can be a paradigm to newer hobbyists for classic speaker configurations.
Old 18th October 2012, 08:08 PM   #723
Sure Salas. If I try it I will post detailed info what I am doing. Like you said it has developed into something more which was not the plan. I can´t help myself beeing curious what if..... I hope it can be of use to someone here although many already have passed that stage and are far more advanced and already have the knowledge.
Old 18th October 2012, 08:18 PM   #724
Salas's Avatar
True, they measure MLS, know tons of stuff about wave propagation, read impulse response with one glimpse, program multi way digital crossovers, materials know how, etc but you never know, there are always first time builders around.
Old 28th October 2012, 08:19 PM   #725
I have moved the speakers to try if it works, this is how it looks:
Old 28th October 2012, 08:32 PM   #726
Measuring 1 metre stereo from back wall:
Old 28th October 2012, 08:37 PM   #727
Measurings near field with both speakers playing, 0,3m/0,5m/0,75m:
Old 28th October 2012, 09:54 PM   #728
And how does it sound? Better than before! No "shouting" in the middle range, cleaner more intimate sound from singers, more detail and purer treble. Over all you can hear that the removal of side reflex sound is a big help. Bass works good too, good level and quite even.
Old 28th October 2012, 10:09 PM   #729
Salas's Avatar
So the solution was really "out of the box". You get very good "house curves". If you will have a look around for raw RTA stereo playing curves there are much much irregular situations to find. Even with bass traps etc. Congratulations.
Old 28th October 2012, 10:19 PM   #730
Thanks Salas, the interesting thing is that the RTA measurings does not look very different now compared with before moving, but it is a big difference in sound so I guess this RTA does not show very much how room reflexes affects the sound. I will do a full Room Analysis and also full range measuring later because I think it will show more how it really is. Also I have to solve how to get placement of all things like TV and sofa to work with this new position, not easy at all....
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
