#61 | |
Besides that, i think you should be OK
#62 |
Ok, but I have decided to use it as is but remove one of the tags closest to the edge. In that way I will not risk anything to crack. I will also put some glue under the t-nut before driving it in. I only have this problem on one of the tweeter ( I made the hole a little too big).
#63 |
I tried driving them in without removing a tag but I got a slight cracking (delaminating) so when mounting the woofers I will remove one tag per T-nut closest to the edge of the hole for the woofer to make sure it doesn´t crack. I used a hammer taking it slow and easy but I think the delaminating could be avoided if not using a hammer, driving it in with a screw and washer. I will try this next time. Takes experience to mount these it seems.
#64 |
Finally all nuts in place
. Now I am having trouble choosing internal cabling and terminals.
#65 |
Pictures of the baffle and I got some speaker terminals today, from Jantzen audio, about 9 Euro per terminal. Seem sturdy and quite heavy.
#66 |
Got some cheap 2.5mm speaker cable, I think it will do to start with. This weekend I will do the crossover and hopefully play a little to see if everything is ok! Exciting
#67 |
great starre, looking forward for your first impression.
i checked back the stereophile review of your performa, they are indeed great speakers. measured very well also. cheers henry |
#68 |
I hope these goodies can make a pair of crossovers...
#69 |
Reminds me a bit of an updated DBS4- a kit design in the now log defunct UK magazine Practical Hi-fi, designed by Dave Berriman.
#70 |
diyAudio Chief Moderator
You mean a closed box one with proprietary woofer and Morel tweeter?
| Building a simple "soft start" speaker protection circuit | richard.C. | Power Supplies | 21 | 6th August 2011 08:12 AM |
| "Commercial" install in NP Building Material Store | Destroyer OS. | Everything Else | 2 | 19th July 2010 04:15 AM |
| "TECHNO"Amp building in progress-using "Iron Method" | zox2003 | Solid State | 23 | 30th March 2010 08:42 PM |
| Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF | 454Casull | Multi-Way | 0 | 18th November 2008 02:19 AM |
| 10" basS/mid for "party-speaker" | TroelsM | Multi-Way | 0 | 16th September 2005 11:14 PM |
