"Tired2way" speaker building.
Old 26th September 2012, 11:34 PM   #661
Starre is offline Starre  Sweden
Yes I have to consider balance, going to check how heavy it is.
Old 27th September 2012, 09:18 AM   #662
Dim. will be 25x60x1cm. I wonder how thick layer of glue is suitabel for best result, thick or thin? Anyone has an idea?
Old 27th September 2012, 10:58 AM   #663
It would only be about 4kg so maybe I need thicker. 2,5cm would make it 10kg.
Old 30th September 2012, 09:22 PM   #664
I have discovered something, I have had some shoutiness in the sound mid range and blamed the back panel. But after using some other coupling between speaker/stand/floor it is sounding better. Very sensitive it seem.
Old 30th September 2012, 09:34 PM   #665
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
If you start the cabinet-stand-room perfection train trip it has many stations.
Old 30th September 2012, 09:36 PM   #666
Salas's Avatar
If others don't share the room to impose some sanity soon it ends up like a studio...
Old 30th September 2012, 09:44 PM   #667
I think I will stay at the station for now. I have to decide if I want to reinforce the back and how. Maybe I will hear no difference anyway.
Old 30th September 2012, 09:59 PM   #668
Seem I lack some sanity in this regard, get carried away with some kind of hifi obsession. I obviously is a little out of balance.
Old 30th September 2012, 10:20 PM   #669
kevinkr's Avatar
That is perfectly understandable, and we encourage that here.. I'm an extreme case..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 30th September 2012, 10:21 PM   #670
Salas's Avatar
Yep, not against. Just future tellers.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 09:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 05:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 09:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 03:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 17th September 2005 12:14 AM
