Old 22nd September 2012, 06:23 PM   #641
Starre is offline Starre  Sweden
Maybe a 5mm alu panel fastened with damping glue would do the trick. But not so easy to implement. Some very dense wood panel is easier to get hold of I guess.
Old 23rd September 2012, 08:06 PM   #642
I am pondering using ceramic tiles with damping glue. But before that I must test with a bit of MDF if it can be a good choice. The tile is stiff and approx 6mm thick. Damping glue of approx 1mm. This way it is rather thin and does not alter the box dimensions very much. Also the surface does not need any work.
Old 23rd September 2012, 08:33 PM   #643
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Making a super duper pair of cabs applying all you've learned and dream of just from scratch would be another upcoming winter pass-time idea though. Then you transplant the organs to the new body (very Frankenstein LOL) and you decide. If you had jumped category to the special cabs success stories club then you may buy more drivers and best crossover parts, duplicate, and sell the normal but reinforced and beautiful white cabs speakers to a very happy adopter who lacks the time and/or skill.
Old 23rd September 2012, 08:44 PM   #644
Decisions decisions....If I understand you Salas you think it would be best to make a new cabinet. But I do not like it remembering that router hard work getting it right lol. I rather try to improve what I got. Do you think it is useless and even destroying what I have you mean?
Old 23rd September 2012, 08:51 PM   #645
Salas's Avatar
Useless no, but I am afraid of when the gradual volume eating will rear its ugly face.
Old 23rd September 2012, 08:54 PM   #646
Ah ok, well that is no problem since I was thinking of using it on the outside of the cabinet, you believed I wanted it on the inside, right?
Old 23rd September 2012, 09:07 PM   #647
Salas's Avatar
Yes inside I thought, outside no problem for volume, but will it not look weird since its a beautiful speaker now?
Old 23rd September 2012, 09:33 PM   #648
It might look weird , I was thinking something like this picture, just a free hand sketch. Side-back-side. White tile trying to match color, and I think it is possible to paint the tile if necessary.
Old 23rd September 2012, 10:42 PM   #649
Salas's Avatar
Just don't end up with a tiled hospital bathroom look since its whitish already.
Old 24th September 2012, 07:18 AM   #650
Zvuchniak's Avatar
Try with wood on sides of the speaker. Something like Sonus Faber.
Stained wood with rounded edges would look nice and the cabinets would benefit from it. The only better thing than two materials glued together with their whole surface for speaker wall is sandwich box filled with sand.
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS. Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Copyright ©1999-2013 diyAudio
