"Tired2way" speaker building.
Old 29th July 2012, 11:36 AM   #611
Starre is offline Starre  Sweden
Hi Salas. It seems like to get rid of it I will need a very solid support of some kind on that panel, we will see if I can make it. Aluminium sandwich seem interesting but not possible for me to make. This speaker company is rather interesting, a review of one model:
Piega TC30x: STEREO | Zeitschrift für HiFi, High End & Musik
Old 29th July 2012, 08:07 PM   #612
I put in a rib at the back, tomorrow I will listen if it did something, hopefully good.
Old 30th July 2012, 09:51 AM   #613
A slight dampening it is, better than nothing. In total the volume is 0,81 liter less now. Salas, what happens to bass when you decrease volume and keep the rest unchanged? Do you get a little hump the more you decrease it?
Old 30th July 2012, 09:55 AM   #614
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
It peaks a bit a and moves up in frequency a bit.
Old 30th July 2012, 10:54 AM   #615
_henry_ is offline _henry_  Australia
u can do simulation with this site
mh-audio.nl - Vented System
Old 30th July 2012, 01:36 PM   #616
Thanks Salas and henry. I will do the second speaker and post a picture how it looks inside later.
Old 30th July 2012, 06:07 PM   #617
Ok, almost finished. After it is dry I put some new stuffing in place ( I ditched the fleece lining and removed all behind woofer while testing). I listened some more and also knocked on the back and it is clearly more stable, mission accomplished. Picture of inside, quite a construction site . The rib is 19x27mm with the smaller side against the back for max stability. With this placement it gives support on the whole panel behind woofer with just one rib, and gets support from the upper and lower bracing.
Old 30th July 2012, 06:40 PM   #618
Salas's Avatar
3D Matrix tuner man!
Old 30th July 2012, 06:59 PM   #619
Lol :-). I should apply for a job at B&W...
Old 30th July 2012, 08:04 PM   #620
Stuffing back, drying over night.
"Tired2way" speaker building.Hide this!Advertise here!
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Copyright ©1999-2017 diyAudio
