#591 |
diyAudio Chief Moderator
But you improved control with the front to back rods somehow?
#592 |
A small improvement, yes. I think it made the hole speaker sound a little more agile.
#593 |
My latest idea is to put a rib vertical from the new front-to-back panel up to the upper front-to-back bracing at the back. I think it might help a little, do you think Salas, it will affect something else, like bass output? It is 27mm wide and 19mm deep.
#594 |
Can't guess. Did you estimate how much active volume you had taken away by now?
#595 |
Yes it is a guess, up to me to try. I estimate at the moment somewhere between a half and max one liter. Edit: I calculated it to 0,6 liter as it is now.
#596 |
I will do nothing more since I am not certain, leaving it for now. I tried with squeezing a rib in place as described above, and a slight difference it maybe was, not sure.
#597 |
I have 2 good CD to use for testing speakers, I have learnt they are demanding:
Diana Krall: Live in Paris Norah Jones: Feels like home |
#598 |
Live in Paris always sounds boomy and messy on my speakers.I can't really follow the bass lines ):
How does it sound on your speakers Starre? |
#599 |
I will answer you tomorrow, need sleep.
#600 |
this is exactly what I'm looking for!
| Building a simple "soft start" speaker protection circuit | richard.C. | Power Supplies | 21 | 6th August 2011 08:12 AM |
| "Commercial" install in NP Building Material Store | Destroyer OS. | Everything Else | 2 | 19th July 2010 04:15 AM |
| "TECHNO"Amp building in progress-using "Iron Method" | zox2003 | Solid State | 23 | 30th March 2010 08:42 PM |
| Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF | 454Casull | Multi-Way | 0 | 18th November 2008 02:19 AM |
| 10" basS/mid for "party-speaker" | TroelsM | Multi-Way | 0 | 16th September 2005 11:14 PM |
