"Tired2way" speaker building. - Page 6 - diyAudio
Old 24th October 2011, 09:36 AM   #51
_henry_ is offline _henry_  Australia
its one of the few commercial speakers that i like. they have tremendous bass performance.
good luck !
cheers
henry
Old 24th October 2011, 09:41 AM   #52
btw,
its still an expensive emergency clamps ..
cheers
henry
Old 24th October 2011, 09:42 AM   #53
Starre is offline Starre  Sweden
Thanks henry, it is a nice speaker but needs a lot of power to sing.
Old 24th October 2011, 10:42 AM   #54
I believe the HDS tweeter is better than the one used in my Revel Performa, we will see about that soon.
Old 24th October 2011, 10:46 AM   #55
i always wondered, what kind of level of drivers they use for the commercial products. For harmann, prob its not that easy to measure, since they manufactured in house and for several brands.
What makes u decide to use HDS tweeters?
cheers
henry
Old 24th October 2011, 10:54 AM   #56
I liked what I read online, and it seems a sturdy quality tweeter. Only negative I have read about it is a slight raise of level around 4kHz or something like that, but some say it is not necessary to fix this with the cross over, some say you should. The big picture seem to be a good quality tweeter with nice sound, good extention uppwards and a reasonable price.
Old 24th October 2011, 08:20 PM   #57
I have drilled the holes for the drivers, but I noticed when I tried to mount T-nuts it is not very much wood to mount it on, I am afriad it will crack. I need some advice doing this.
Old 24th October 2011, 09:03 PM   #58
Zvu is offline Zvu  Serbia
Zvu's Avatar
Try this:
... putting a piece of MDF behind front panel. Radius of the back panel would be the same as the inner radius of the front panel. This is just simple task of adding more material so that you have something to mount T-nuts in.
Old 24th October 2011, 09:15 PM   #59
Yes that is one way, ty Zvuchniak. I am rather close to the edge, I was even considering turning the T-nuts upside down and use glue, but maybe that will be even worse?
Old 24th October 2011, 09:29 PM   #60
Maybe if I am careful driving it in slowly it will be ok .
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Copyright ©1999-2017 diyAudio
