"Tired2way" speaker building. - Page 59 - diyAudio
Old 20th July 2012, 04:53 PM   #581
Starre is offline Starre  Sweden
It has a vent hole. I might just do that, we will see, thanks.
Old 20th July 2012, 05:06 PM   #582
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Having a vent its a no go.
Old 20th July 2012, 05:34 PM   #583
You mean it needs the open space in full behind it? Well too much work anyway. I think I will do a rod from that bracing straight to the back, no angle upwards. Start with that and try to listen before I do anything else. I already put a new bracing from front to back below the woofer on one speaker.
Old 20th July 2012, 05:39 PM   #584
Salas's Avatar
The vent is for cooling the coil, you can't afford to block it with a rod. And there is no good way to do it like a claw that grabs the magnet and lets its axis vent breath in a finished speaker.
Old 20th July 2012, 05:42 PM   #585
I will skip on that and just try to stiffen the cabinet.
Old 20th July 2012, 07:54 PM   #586
I tried a rod from the side bracing to the back but was not convinced, I just squeezed it into place and listened and then removed it. It made some new unwanted sound. The extra front to back bracing seem to do something good, but no big difference. Left to try would be a rib at the back, but that is hard to try since I have to glue it permanent first. Also I could try some foam and see what happens, probably not much like you said Salas.
Old 20th July 2012, 09:29 PM   #587
Salas's Avatar
Could you just screw in the back rib for a test?
Old 20th July 2012, 10:14 PM   #588
No I don´t want that, risking a crack or something. I will do some tests after breakfast what I have, I have put in that foam in the back just to check what happens. I will sleep on it Salas, what to do with testing a rib. Good night Salas!
Old 21st July 2012, 11:30 AM   #589
Front-to-back rod glued in place in second speaker, It did not do very much but it should be the same in both speakers so I put it in. After drying I can test if some foam at the back makes a difference by comparing one with and one without it the rest being the same.
Old 21st July 2012, 04:18 PM   #590
That foam did very little reducin back-panel sound, but I noticed a sligth reduction of bass, so it will be removed. Next step will be how to test a rib at the back without gluing, or I take a chance put in one to start with. It is when hitting a piano note hard, or plucking a string hard on electric guitarr these "sounds" is heard from the back coloring/emphasize sound.
Building a simple "soft start" speaker protection circuit richard.C. Power Supplies 21 6th August 2011 08:12 AM
"Commercial" install in NP Building Material Store Destroyer OS Everything Else 2 19th July 2010 04:15 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
Copyright ©1999-2017 diyAudio
